Which grease? Indicator switch/switchgear.
DrDonnyBrago
PostPosted: 10:49 - 25 Mar 2014    Post subject: Which grease? Indicator switch/switchgear. Reply with quote
Morning chums,
I've had a temperamental indicator switch for quite some time. I clean it and regrease and it works for a few months, then the grease gets between the contacts and makes the connection somewhat dodgy. I've taken to not greasing the contacts, but it always seems to work its way back in and bugger up my indicators.
So..... I've been using lithium grease, what grease SHOULD I be using? Links to any obscure unobtanium greases would be appreciated Thumbs Up .
PostPosted: 11:00 - 25 Mar 2014    Post subject: Reply with quote
Could use this:
https://www.grainger.com/product/THOMAS-BETTS-Copper-Compound-Cable-Dressing-3LP02?Pid=search&cm_mmc=PJX-_-GraingerBrand-_-43737-_-Generic
Probably not a good idea to use a grease that conducts as then if it moves where it shouldn't, you'll end up short circuiting everything.
Why do you need to keep greasing your switchgear? Surely a bit of WD40 would give you enough lube/drive the moisture out.
Islander
PostPosted: 11:20 - 25 Mar 2014    Post subject: Reply with quote
If you're going to grease them then use vaseline.
temeluchus
PostPosted: 13:25 - 25 Mar 2014    Post subject: Reply with quote
https://image19.spreadshirt.com/image-server/v1/compositions/105038910/views/1,width=178,height=178,appearanceId=63/George-Takei-Oh-Myyy-mp-T-Shirts.jpg
Copycat73
PostPosted: 13:40 - 25 Mar 2014    Post subject: Reply with quote
with electrical contacts your supposed to use silicone grease..
not that many peeps do .. including myself at times ..
https://www.wickes.co.uk/silicone-lubricant-grease-500g-tub/invt/227226/?source=123_74&tmcampid=104&tmad=c&tmplaceref=PPC_ggl_0006635&tmcustom=mkwid|W5fPyZGt_dc|pcrid|7531858372|match||plid|&gclid=CI6Q_fvZrb0CFc_MtAodlj4AWA
caveat emptor
DrDonnyBrago
PostPosted: 14:39 - 25 Mar 2014    Post subject: Reply with quote
I've opened it a few times to remove some of the grease that has worked in between contacts, think I only greased it the first time. Didn't apply much either, seems to get blasted into funny places and/or melt in our glorious sunshine.
WD40 pretty much started my issues. I had a crunchy indicator switch, gave it a squirt of WD40 and it packed in shortly after. It dissolved the dry crusty old grease and let a big blob of it in the way of the sliding contact. Upon opening it was filthy with grit and all all of the components had signs of wear. Grease was to stem the wear and stop my indicator switch being stiff, it worked, kinda.
Would red rubber grease be better than lithium?
Busa1340R
PostPosted: 14:49 - 25 Mar 2014    Post subject: Reply with quote
How about some of this then.....
https://www.ebay.co.uk/itm/Dielectric-Grease-for-contacts-and-connectors-/380370452070
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
PostPosted: 16:35 - 25 Mar 2014    Post subject: Reply with quote
Probably be the same. I'd suggest just using the smallest amount of grease possible.
map
Mr Calendar
PostPosted: 16:55 - 25 Mar 2014    Post subject: Reply with quote
If you want grease in there I'd go for silicon or dielectric type.
I know the silicon based stuff is waterproof and non conducting.
Dielectric is non conducting but can't vouch for how water resistant it is.
If there is any desire to use Vaseline do not confuse and pick up the KY jelly. That's water based after all and would be bad.
WD Forte
PostPosted: 22:56 - 25 Mar 2014    Post subject: Reply with quote
Not keen on using WD40 for electrics meself
I tend to use that for the cheap throwaway jobs or cleaning
I suggest you clean it out and inspect the contacts for wear first.
Flasher switches being a high use item can just wear out,
so whatever jollop you choose, it wont help if this is the case.
I use switch cleaner or ACF50 on mine but vaseline (petroleum jelly)
is good for lubrication and preventing water ingress
as long as the switch is mechanically sound to begin with.
bikers smell of wee
The last post was made 12 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 67.28 Kb
