| Andy_Pagin |
 Andy_Pagin World Chat Champion
| map |
 map Mr Calendar
 Posted: 23:20 - 25 Mar 2014 Post subject: |
Probably (and hopefully) worn bushes/brushes (I've seen both terms used).
You'll need to remove and take apart to check.
For a hint do a search for CB500 starter on here. I suspect (although not checked) the likes of WEMoto will have replacement parts. If the starter hasn't welded itself to the engine and can be removed it's a relatively easy fix.
I have similar issue on the CB500 (hence why I know solution posted here). Occasionally hit starter and it just clicks. Put in 2nd gear and rock forward (similar to push start but not used to start). Then hit starter and fires up.
Best of luck  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| gdj444 |
 gdj444 Borekit Bruiser
| moonzoomer |
 moonzoomer World Chat Champion
| map |
 map Mr Calendar
| Andy_Pagin |
| Major Doss |
 Major Doss Traffic Copper
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
