| Saltire |
 Saltire Could Be A Chat Bot
| Quornholio |
 Quornholio World Chat Champion
| Saltire |
| Quornholio |
 Posted: 18:58 - 27 Mar 2014 Post subject: |
Are the lights and everything else working?
A TOTALLY flat battery will sometimes result in a green light on a modern charger. It just assumes it isn't connected to anything.
If they are. Try shorting between the terminals on the solenoid using an old screwdriver (sparks will fly). This ought to turn the starter motor even if the ignition is off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jimmyRS |
 jimmyRS Scooby Slapper
| Saltire |
 Posted: 19:44 - 27 Mar 2014 Post subject: |
Nah no lights, nothing. I tried jump starting it and still no juice so I am starting to think it is the ignition barrel/wiring itself.
Not checked the fuse as I'd need an ammeter, I think, but I will just in case .
Will take some pics of the botch job on the ground wire that's been done but again, I don't think that would cause the issue, was just frying my battery before it was done.
Not really sure where to start when checking the ignition, guess having a look at the wires I can see and making sure they are connected together can't be too wrong.
Note to self; do maintenance course ASAP. |
| P.addy |
 P.addy Red Rocket
| misscrabstick |
 misscrabstick Crazy Courier
| Whosthedaddy |
 Whosthedaddy Super Spammer
| J.M. |
 J.M. World Chat Champion
| Saltire |
 Posted: 20:23 - 27 Mar 2014 Post subject: |
I have checked the fuse and it seemed fine, there was also a replacement fuse in the cartridge so i replaced it and tested just in case but still nothing.
Tried the solenoid trip method and it would crank the engine (which tells me the battery and fuse is okay?) but the bike obviously wouldn't start, I imagine because of the lack of input from the ignition barrel
All advice appreciated people thanks! |
| map |
 map Mr Calendar
 Posted: 20:26 - 27 Mar 2014 Post subject: |
I had similar issue with GT. Key turned but no power. Put wd40 and even 3in1 oil down barrel. Worked key in and out of barrel. Sorted the problem.
If bike left out in recent cold and rain it might be similar fault. Hope you get sorted. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Saltire |
 Posted: 20:54 - 27 Mar 2014 Post subject: |
Thanks everyone, I have got her started and let her run like she well needed at last.
The ignition barrel has changed it's sweet spot on me but I think maps' advice on the wd40 helped uncover it as I was getting nothing before - thank you map!
Minor (hopefully) issue though - after having the bike started no more than 4 minutes I noticed some smoke coming off of the start of the exhaust in the way you would see if there was dry material on an unlubed hot frying pan. I know it is probably from me wd40ing it whilst it was out of action but should the exhaust be getting hot enough to do that so quick? I did have it on choke so obviously that's a factor but still. May be a daft question but I'd rather ask it and be safe.
Again, much appreciated BCF  |
The last post was made 12 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
