2 Stroke problems, again!
MattWadz
PostPosted: 22:01 - 28 Mar 2014    Post subject: 2 Stroke problems, again! Reply with quote
Okay, 50cc Two Stroke Peugeot, Liquid Cooled, Sports Exhaust system (Doppler) standard 12mm Gurtner carburettor.
When i first start the bike, it will idle fine, but when i try to accelerate, it splutters alot as the revs go up, from cold ish as if its clearing its throat sort of thing Razz
Once its up and running it will run well, as soon as i give it hard acceleration or just ride it normally for about 1 minute, when i take it back down to idle and try and pull back off again it seems asif the engine is dying, asif someone is slowly smothering it, and even when i give it throttle when this is happening it just seems to bog. if i wait and restart it, it will be okay but still spluttery.
Any ideas on what this could be?
i thought it could be a mixture issue but im lost as to where to start, too rich too lean, id rather find out first because its quite awkward to keep taking the float bowl off to change the main jet!
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
SQL
PostPosted: 22:09 - 28 Mar 2014    Post subject: Reply with quote
plug chop it
MattWadz
PostPosted: 22:11 - 28 Mar 2014    Post subject: Reply with quote
plug chop means run it flatout under load and then quickly shut it off, whip the plug out and check it for colour right?
tan brown/coffee colour?
andys675
PostPosted: 22:21 - 28 Mar 2014    Post subject: Reply with quote
faulty auto choke?
MattWadz
PostPosted: 22:23 - 28 Mar 2014    Post subject: Reply with quote
could be auto choke, although im pretty sure it works fine because when i start the bike from cold, it idles high for about a minute, and then the idle drops back down to normal then, surely this indicates that its working correctly?
I could be wrong!
andys675
PostPosted: 22:32 - 28 Mar 2014    Post subject: Reply with quote
remove the auto choke when cold, and wire it direct to the battery one lead positive and one to the negative, measure how far the brass valve on the end sticks out, after 10 minutes there should be a distinct difference between the two measurements, over 1cm iirc, if there is the auto choke is fine
MattWadz
PostPosted: 23:46 - 28 Mar 2014    Post subject: Reply with quote
what causes the auto choke to move? is it just a timer or resistance?
lukamon
PostPosted: 00:18 - 29 Mar 2014    Post subject: Reply with quote
if its like most scooters, its a small cylinder full of wax that expands (contracts?) when heated and it melts, pulling in (pushing out?) the pin. if the heater fails, no movement, choke stays on, bike runs shit Thumbs Up
killa wrote: Im an ass man myself
evoboy
PostPosted: 02:52 - 29 Mar 2014    Post subject: Reply with quote
Has it been jetted up to suit the new pipe?
APT Motorcycles
Boxing
PostPosted: 06:58 - 29 Mar 2014    Post subject: Re: 2 Stroke problems, again! Reply with quote
So, I take it you haven't been 100% sure on the jetting settings for the sports exhaust you have? Rolling Eyes
You do realize if you've been riding it around with the incorrect jetting and its been running lean, your piston is most likely gone.
I'd do a plug chop. Go down to your local bike shop, explain what bike and model you have, and tell them you need a spark plug. I got mine for about £3 but the prices vary. (Could eBay job it if you want)
Then do a fresh plug chop on the new plug.
Refer to this guide:
https://mopedriders.org/html/manuals/tomos/a35/a35p017.jpg
GL Thumbs Up
MattWadz
PostPosted: 19:10 - 29 Mar 2014    Post subject: Reply with quote
It has covered about 1 mile since ive had it, with a brand new barrel piston head, and crank. im not sure what jetting would have been standard! i think thats the issue!
also, it wont start unless i cover the air intake on the airbox, soon as its started i can take my hand off then :S
So spun out!
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 68.95 Kb
