| Jarrett1988 |
 Jarrett1988 L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
| Jarrett1988 |
 Posted: 20:39 - 30 Mar 2014 Post subject: |
Hello mate yeah all the valves are free and it is the cg 125 ohv engine. I just can't work out why it's not starting its got good compression  |
| Pigeon |
 Pigeon World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| bladerunner |
| Teflon-Mike |
 Posted: 07:55 - 31 Mar 2014 Post subject: |
Keihin PD26 carburettor.
Probably one with accelerator pump.
Fuel pissing out the vent hole sounds perfectly normal to me
Drop the float bowl; clean the float needle and seat.
Re-assemble.
If it still pisses, let it; try starting no choke no throttle; those float needles can be a bit sticky and need the engine run a bit to 'bed' and find thier seat.
Meanwhile; don't let the slightly high float bowl fuel level flood the engine, hence no choke, and if it still wont catch, open throttle 1/8th turn at a time and let it drag extra air to weaken it out a bit and give it a chance to catch.
If a pumper carb... has two cables from the throttle.... check the accelerator pump; I believe there is a diaphragm in there, could be perished, and causing your leak.
Also, on Pumper carbs under NO circumstances 'wank' the throttle whilst starting. Every time you change throttle position, pumper is squirting neat fuel into the carb, to enrich mixture under acceleration, to compensate for over-lean jetting, to meet emmission regs.
Could also be cause of fuel pissing out of carb if thats' what you are doing, and or pumper cable adjustment too high. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Jarrett1988 |
The last post was made 12 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
