VT750 Fuel Leak
The Disapproving Brit
PostPosted: 08:44 - 31 Mar 2014    Post subject: VT750 Fuel Leak Reply with quote
I ran out of fuel a few days ago (dealer left it on reserve and I never checked) - since then, I've noticed that, when the bike is on its side stand, fuel is coming out of somewhere around the carb.
A bit of research suggests that the most likely culprit is a bit of crap from the dregs of the tank making its way into the float, causing it to overflow. I'm still in warranty, but I don't particularly fancy being off the road while the dealer sorts it.
I'm thinking that if it is just a bit of crap in there, maybe I can flush it out by turning the fuel off and letting it run dry again, then turn the tap back on to pump it through. Is that likely to a) work, and b) do any harm?
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Islander
PostPosted: 09:17 - 31 Mar 2014    Post subject: Reply with quote
Check the float valves. You've probably pulled some crap though causing one of them to stick. If it's in warranty then let the dealer do it. Thumbs Up
PostPosted: 10:24 - 02 Apr 2014    Post subject: Reply with quote
Thanks. I tried running the carbs dry a couple of times, and it didn't help, so it's booked in for the dealer to sort.
The last post was made 12 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 36.3 Kb
