| hunterfett |
 hunterfett Two Stroke Sniffer
 Posted: 14:25 - 31 Mar 2014 Post subject: 1983 GS 125es wont start help needed |
Hi all.
I dont know anything about bikes but ive just passed my cbt as im being given a 1983 gs 125 es for nothing. the bike was running and went through an mot fine but since then(2years ago) has not been touched. it has fallen over a few times and bent the handlebars and wrecked the tacho dial. i put a new battery on it but nothing no lights, horn indicators etc, completley dead so it wont start any tips on where to start with this ive orderd a haynes manual. but need to get this thing up and running as im skint and need it for comuting to work and back.
all help and advice greatly received  ____________________ cheers all |
| hunterfett |
| WD Forte |
 WD Forte World Chat Champion
| hunterfett |
| WD Forte |
| hunterfett |
| map |
 map Mr Calendar
 Posted: 16:17 - 31 Mar 2014 Post subject: |
Check simple stuff first before starting to dismantle. If no electric (lights, etc) at all with new battery then check
1. As said, main fuse. Should be about 30amp rated, near the battery (follow red lead).
2. Could be ignition barrel. Cold/damp could affect it. Spray WD40 down barrel and work in and out with key. Try this a few times. Then try inserting and turning key to see if power. You might have to jiggle key in the barrel. Check for any chopped wires from barrel.
Obviously check connections are tight to new battery.
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| hunterfett |
| hunterfett |
| moonzoomer |
 moonzoomer World Chat Champion
| The Artist |
 The Artist Super Spammer
| hunterfett |
| moonzoomer |
| hunterfett |
| hunterfett |
 Posted: 22:41 - 12 Apr 2014 Post subject: |
so a quick update firstly thanks for all your help and sugestions its been a real help. so i got the bike running cleand it up a bit and put it in for MOT only went down on a front wheel bearingwhich has now been sorted and now has a years ticket. however riding home this evening i noticed that the brake light wont work while the lights are on and i have no tail light. figured id best get home before it gets dark and on the way bake all the electrics start playing. healights slowly diming indiciators not flashing just staying on constantly. then the bike starts to chug a bit backfired a couple of times and as i pulled onto my driveway the bike died no electrics at all. put the battery on charge and was fully charged within about 15 mins so im guessing the battery is not the problem its only 2 weeks old. when i put the battery back on to try it i got all electrics back temporarily but now nothing again. any ideas im really stuck without my bike please help    ____________________ cheers all |
| hunterfett |
 Posted: 20:11 - 14 Apr 2014 Post subject: |
managed to sort electrics problem turns out it was just a bad earth all sorted now and thought i would share a pic  ____________________ cheers all |
The last post was made 12 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
