Getting oil sight glass clear again...
map
Mr Calendar
PostPosted: 13:24 - 31 Mar 2014    Post subject: Getting oil sight glass clear again... Reply with quote
My lad's Varadero XL125V has had an issue with the oil.
I'd think some water in the oil, the oil level sight glass is cloudy (opaque).
He seems to think something to do with the carb originally. I can't say.
Anyhow, oil changed. Looked ok, not milky.
Ran up fine. Sight glass still cloudy though.
I'm thinking a longish run up to decent temperature might help clear.
Followed by another oil change.
Would this help?
Or has the glass/plastic (whatever it's made from) just gone with age/use (unlikely given I've much older machines with clear glass, but it was a thought).
Any other pointers appreciated Thumbs Up
SQL
PostPosted: 14:17 - 31 Mar 2014    Post subject: Reply with quote
Cane the nuts off the bike for a bit
Matt B
PostPosted: 14:19 - 31 Mar 2014    Post subject: Reply with quote
Some (like on my Pan) can be removed without taking off the engine covers, but I bet the Varadero one is fitted from inside?
I reckon getting up to temperature on a few good runs and it should clear. Seems unlikely that the glass has clouded, probably just covered in white gunge.
Nemo
PostPosted: 15:29 - 31 Mar 2014    Post subject: Reply with quote
Probably just condensation.
As the others have said, warm it up and give it a few runs, should clear, one of my bikes had the same problem.
If you're not loosing any coolant then I wouldn't worry too much about it.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
The Disapproving Brit
PostPosted: 16:03 - 31 Mar 2014    Post subject: Reply with quote
If it's bothering you, drop the oil, whip the case off and give it a wipe from the inside.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
PostPosted: 19:32 - 31 Mar 2014    Post subject: Reply with quote
Be sure to check the oil level in the sight glass first. Don't want to cane your bike if the oil is low Smile
The last post was made 12 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 49.48 Kb
