Advise pls.. Dt 125cc full power.
Mac999
PostPosted: 20:32 - 31 Mar 2014    Post subject: Advise pls.. Dt 125cc full power. Reply with quote
Hi I'm intrested in buying a dt 125cc 52 reg... Full power (powe valve)
I'm on a cbt licence I'm over 40 yrs old
I was told I wasn't allowed to ride it under l plates
Is this true Smile
Irn-Bru
PostPosted: 21:18 - 31 Mar 2014    Post subject: Reply with quote
Technically no you're not allowed to ride them. I think full power ones are 20 bhp or possibly more which is more than the limit of 14.6. Doubt it would ever matter but it's your risk to take. I had a full power DTR while on a CBT, then a bike over 33bhp (just) on my restricted license and I didn't die or kill any kittens.
My main concern on a DTR that old would be condition, it's bound to have been hammered unless it's a mature owner. What is the milage? And if high has it had a rebuild? They are good engines but like all 2 strokes need attention eventually. I think the highest mileage one I had heard of on the original top end was around 20k which is decent I reckon if the lad wasn't lying anyway.
_mjs_
PostPosted: 22:45 - 31 Mar 2014    Post subject: Reply with quote
You also need to find out if the powervalve actually works properly. If it is when you turn the key you'll hear a double 'bzzt! bzzt!' sound which is the valve opening and closing to clean itself.
Unfortunately nine times out of ten some chavmong will have interfered with it thinking they are derestricting it and locked it open. This results in a bike with all the power coming in at the top end and very sluggish low down.
bladerunner
PostPosted: 12:35 - 01 Apr 2014    Post subject: Reply with quote
On a 52 plate it'll have the pv and gubbins fitted. To restrict it...go to your local Yamaha dealer...they plug in a box and it sets your servo to restricted and they will give you a certificate to say its now learner legal.( no actual requirement for the certificate)....that's all totally legal job done......however I'm guessing your a full licence holder and experienced road user....the extra hp sure makes them a bit more manageable on NSL roads hills and head winds!
DT and KMX 125's were in my mind the best of the learner legal 125's as reliable as a 4t but with more torque and the added advantage of green lane fun and both easily derestricted to 85mph without much effort
Just make sure it's been looked after.
Teflon-Mike
tl;dr
PostPosted: 12:41 - 01 Apr 2014    Post subject: Re: Advise pls.. Dt 125cc full power. Reply with quote
Is this true Smile
True.
Learner restrictions, as you should have been told when you did CBT, are you are allowed to ride a solo motorcycle up to 125cc, up to 11Kw (14 and a bit bhp) and with a power to weight limit under 0.1Kw per Kg; for up to two years .
DT125, depending on age, might not even be allowed the full 11Kw, as some of them are under 110Kg. The 20-24bhp they might make as standard, if genuine factory 'full-power' variants, could make them Full unrestricted A /A3 licence bikes, due to 0.2Kw/Kg limit on A2 'restricted' licence for 19-24 year olds.
Solution? If you want tto ride that bike legally, pass tests, get licence. Its not like you are 17 and aren't old enough to qualify for one.
And if you cant be bothered, then don't bother at all.
Its just ignorance or laziness that says stay on L's. And neither tendency is conducive to a long and healthy enjoyment of motorcycles.
But, get the licence that lets you ride that bike legally, would also let you ride pretty much ANY bike legally... in which case would you still want it?
Ride it illegally? Why bother. If you are prepared to ride other than in accordance with your licence, why not just get an R1 and be done? Riding that with no insurance or licence is no more illegal, and at least you would have performance worth boasting about for your crimes.
The last post was made 12 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 51.85 Kb
