NTV 650
Bikercem
PostPosted: 23:01 - 31 Mar 2014    Post subject: NTV 650 Reply with quote
Hi, all of a sudden my bike doesn't seem to start, and it runs very strangely on a bump start, like the clocks go mental, it does like 20mph max and sounds like its going mental, I've considered maybe the battery is dead, but surely if you can bump it, it would run off of the alternator charge?
I've checked for loose wiring and sorts, no fuses have blow either
fatpies
PostPosted: 23:44 - 31 Mar 2014    Post subject: Reply with quote
Check the starter relay (as in replace with a new one or borrow one and try it with that one, as you can't service them).
It's next to the battery, they tend to rot and cause symptoms on many Hondas.
sickpup
Old Timer
PostPosted: 23:51 - 31 Mar 2014    Post subject: Reply with quote
A better description would help.
Bikercem
PostPosted: 00:16 - 01 Apr 2014    Post subject: Reply with quote
Battery slowly builds up over time whilst key turned on.
When using anything on the bike that requires battery use it only works for however long.
Bump started it couple of times, worked fine, idled, then after driving. a bit it just went mental, like the clock would be on redline and rev itself backwards, but the engine would act normally, until I put some throttle it literally sounded like it was misfiring and barely running and then eventually cut off, I put it on a battery charger and the charger said it was fine
sickpup
Old Timer
PostPosted: 00:33 - 01 Apr 2014    Post subject: Reply with quote
Sounds like the battery is way past its best possibly with added corrosion in the starter relay which feeds power into the main loom. Probably completely dead charging system as well.
map
Mr Calendar
PostPosted: 09:44 - 01 Apr 2014    Post subject: Reply with quote
If rev counter bouncing about for no reason then maybe ignition coil.
I had similar symptoms on a Kwak GT550.
Replacement coil fixed the problem.
As said above though, fresh battery needed.
However, then make sure you check charging system is ok.
Don't want to fry a new battery.
Bikercem
PostPosted: 13:30 - 01 Apr 2014    Post subject: Reply with quote
Ah, how would one check for ignition coil/charger failure? Multimeter?
ssray
PostPosted: 14:27 - 01 Apr 2014    Post subject: Reply with quote
ntv`s have a plastic 3 pin plug that sits inbetween the rear wheel and the battery, this should be your first port of call, it will either be black and burnt or corroded, you can either cut the wires and remake with a new plug or using shrink wrap connect the wires without a connector
then look at the fuse holder next to the solonoide, these corrode and sometimes just need a new fuse even if the one indide looks ok
Ray
Bikercem
PostPosted: 19:06 - 02 Apr 2014    Post subject: Reply with quote
Turns out it was just battery, threw new one in there and it works like a charm now Smile, cheers for the advice though!
ssray
PostPosted: 15:02 - 03 Apr 2014    Post subject: Reply with quote
You still need to break and make connections, as it cleans them
The last post was made 12 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 64.31 Kb
