Uneven tyre wear on rear - Michelin PR3
Jamey
PostPosted: 22:04 - 01 Apr 2014    Post subject: Uneven tyre wear on rear - Michelin PR3 Reply with quote
How do people.
So the bike (Kawasaki Versys 650, 2010) was in for MOT today and the garage pointed out I had quite severe uneven wear on the back - see attached images (a picture being worth a thousand words and all that). Only thing I'd say is that these pics make it look more mild than it really is. It's actually a bit worse in real life. The more worn side is the right-hand side (offside).
First thing we checked was wheel alignment but it seems fine. Garage checked it using a few methods and when I got home I also checked it both by looking at the notches (fine, both match) and also with a tape measure on both sides (also fine, both matching down to the millimetre).
Now I've read other threads about uneven wear and seen people say it's to do with the camber of the road. I can see how that would account for some of it but mine seems too severe to me. Plus the garage said they hadn't seen anything like it before and if camber was affecting tyres this much you'd think every bike the garage ever serviced/MOT'd would show the same signs... At least often enough that they would have instantly said to me "yeah it's camber, we see it every week" but no such utterances crept forth from their speech holes.
Also my front tyre is fine. It doesn't have uneven wear. So I don't see how the camber could only affect the rear without affecting the front as well.
So what else could be causing it to wear so much faster on the right-hand side? And if it really, truly is camber and there's nothing I can do about it then please can someone recommend me a tyre with a very hard compound and shedloads of meat on it. All I do is commute, I don't even go out at weekends anymore really, so my only concern is longevity. I don't care about cornering or grip or wet performance or any of that. I just want the tyre that will last the longest so please shout if you know which one that might be.
gavbriggs
PostPosted: 22:14 - 01 Apr 2014    Post subject: Reply with quote
Do you live in Milton Keynes? Possibly on the west side and travel to the east side to work?
bladerunner
PostPosted: 22:24 - 01 Apr 2014    Post subject: Reply with quote
Wow....kudos to you commuting and wearing out the sides of the tire that much! From the pic the left hand side looks like it is also wearing heavily....very odd to see that on a road bike rear tbh! Is it dual compound by chance or does you commute have long fast bends?
Also....ever thought about racing???!
Az
It's common for rear tyres to wear quicker than front tyres.
Do you encounter many roundabouts or right turns on your travels?
Bent wheel could be a possibility, although i'm sure you would of noticed this by now.
Could an out of balance wheel be the cause?
Maybe something is causing excessive or extra weight on the rear, right hand side and is causing it to wear quicker.
Jamey
PostPosted: 22:47 - 01 Apr 2014    Post subject: Reply with quote
Thanks for the quick replies all.
Not many roundabouts on my commute, which is South-East London to West London.
I go the same way for both ends of the commute, so everything that's a right-hand bend (or turn) in the morning becomes a left-hand bend in the evening. So you'd think it would even out.
I can't honestly say there's anything that should be causing more weight on the right as everything on the bike is balanced, no panniers etc.
It does seem that other people have also experienced this, I just wonder why the garage had never heard of it if it's a common thing, which it does appear to be from what people say.
So... What tyres have the hardest compounds and most meat on them then?
LongJohn22
PostPosted: 23:00 - 01 Apr 2014    Post subject: Reply with quote
Avon Roadriders have a bit of a reputation for longevity.
Jamey
PostPosted: 23:13 - 01 Apr 2014    Post subject: Reply with quote
Cheers, looking at Avon's site I'm not sure they make them in the right size? I think my rear is 160/60/ZR17.
Also, going by the official blurb on Avon's site it sounds as if the Venom would last even longer? But then again they also say it's available in a wide range of sizes but once again I can't see 160/60/ZR17 listed there.
Az
PostPosted: 23:14 - 01 Apr 2014    Post subject: Reply with quote
Not necessarily… if you take a right/3rd exit on a round about on the way to work, on the way back you'd take the 1st exit/left on the same roundabout and only do a little left turn which would be nothing in comparison to the distance round the roundabout you'd travel if you took the 3rd exit on the way to work.
So you would wear down the right side more if you take the 3rd exit on a lot of roundabouts, this still doesn't explain why it's only affecting the rear tyre though.
But you've already said that you don't encounter many roundabouts so the above is irrelevant.
It would be interesting to know what's causing this weird wear pattern, keep us updated if you ever find out what caused it Thumbs Up
Jamey
PostPosted: 23:24 - 01 Apr 2014    Post subject: Reply with quote
Tell me about it, I'm looking at having to replace an otherwise perfectly good Michelin PR3 just because of this. Will def post back if I find out the cause.
Confusion
PostPosted: 23:28 - 01 Apr 2014    Post subject: Re: Uneven tyre wear on rear - Michelin PR3 Reply with quote
Jamey wrote:
How do people.
That's a typical wear pattern for PR3 tyres used for city and suburban
riding. Mine wore exactly the same way. I reckon the RH wear is due
to roundabouts. Mine lasted for 8400 miles. The centre was probably
good for another 2000 miles. but the RH side was badly worn.
Bandit 650SA, ZZ-R1100
Jamey
PostPosted: 23:33 - 01 Apr 2014    Post subject: Reply with quote
Cheers Confusion... What did you switch to after the PR3, out of interest?
And have you got a hypothesis why it doesn't affect the front tyre? This has got me intrigued, I must say.
Jamey
PostPosted: 00:02 - 02 Apr 2014    Post subject: Reply with quote
Also, I suspect this is probably a retardedly stupid question but I'm going to ask it anyway... If this is a normal wear pattern, is there not an argument for deliberately mis-aligning one's rear wheel in order to attempt to balance out the wear and bring it back to the centre?
I'm not talking about having the rear wheel massively skew-whiff, I just mean having the axle pushed back an extra couple of mm on one side to try to compensate.
I'm sure it's probably a stupid idea but if I don't ask I'll never know.
SQL
PostPosted: 00:05 - 02 Apr 2014    Post subject: Reply with quote
Arent the PR3's set up like this
Supersoft Hard Supersoft
So that wear would be normal
Jamey
PostPosted: 00:12 - 02 Apr 2014    Post subject: Reply with quote
I believe that setup is about right, yep. I guess my question was mostly about why the right was wearing faster than the left. I guess it's becoming clear that it really is camber and the odd roundabout doing the damage. Definitely won't be going for PR3s again. Need to find something designed for long life in 160/60/ZR17 size.
Still interested to hear answers to my (probably stupid) previous question too.
mentalboy
PostPosted: 00:53 - 02 Apr 2014    Post subject: Reply with quote
Time of day travelling could also factor heavily here. Do you get a clear run in the morning, giving it beans and then a traffic riddled commute on the way home?
I've also noticed over the years that there are quite a few riders who sit off centre when riding straights, quite bizarre but if you're one of them it may also factor slightly.
Make mine a Corona.
defblade
PostPosted: 07:18 - 02 Apr 2014    Post subject: Reply with quote
It's not camber, it's just that riding on left hand side of the road means that the radius of every right hand bend is larger than every left hand bend, whichever direction your commute is Wink The right hand side of your tyres do a lot more miles than the left over time.
That is impressive wear for commuting though!! Possibly been running with it a bit under inflated as well?
I've switched back to PR2s from PR3s for my commute - seem to give better mileage; wet grip just as good (or I ride within both tyres' capabilities, anyway); no squirrely feeling on the edges; a bit cheaper.
Richy CB1000
PostPosted: 07:49 - 02 Apr 2014    Post subject: Reply with quote
Two penneth, I get milder version of this on a old BT but can see I go further over on the right than left.
I believe it's just that normally we are more confident over right handers, vision etc... so tend to be over a bit more than a left hander?
davebike
PostPosted: 08:22 - 02 Apr 2014    Post subject: Reply with quote
Typical ware pattern for a Multi compound tyre used for commuting
by a rider who is prepared to lean the bike
New tyres needed
Also look to 1/3 way across from the right on the front tyre most ware will also happen there
Dave
Dave
NC750Xdct + others at work !
[email protected]
Fizzer Thou
PostPosted: 09:22 - 02 Apr 2014    Post subject: Reply with quote
Try this place.They show quite a few tyres in the size that you need
https://www.fwr.co.uk/product/28/avon/Avon-Storm-2-Ultra---SPECIAL-OFFER-ON-PAIRS
Always have a 'Plan B'
YBR Ric
PostPosted: 09:58 - 02 Apr 2014    Post subject: Reply with quote
Thumbs Up and in countries where they ride on the right, the left side of the tyre wears the most...
Hugh Farking Cant
PostPosted: 10:22 - 02 Apr 2014    Post subject: Reply with quote
+1 to this.
One tends to accelerate earlier on a r/hander.
Jamey
PostPosted: 11:53 - 02 Apr 2014    Post subject: Reply with quote
Yeah I definitely follow the evidence Vincent collected in that I feel more comfortable turning/leaning left than I do right.
So far I've seen the Metzeler Marathon Ultra and Avon Venom, both of which appear to be designed specifically for long life / high mileage, which is great but neither seem to come in my size.
Does anyone know of a tyre that is specifically designed for long life (so single compound, hard, loads of tread depth) AND is available in 160/60/ZR17? Or even just R17, I don't need the speed rating so much.
Also, am I right in thinking that the Michelin PR3's are the only PRs that are dual compound? The PR1's and the PR2's are both single compound, is that correct? Anyone know how PR1's compare to PR2's for life? I'd prefer not to go Michelin again if I can find something made especially for high mileage in the right size but that's looking less likely at the moment.
PS Defblade - definitely not under inflated, if anything I tend to err on the side of over-inflation for the extra mileage, but generally I kep them about right, a little under 40psi at the back.
Jamey
PostPosted: 12:30 - 02 Apr 2014    Post subject: Reply with quote
I was looking at the Metzeler Tourance Next but noticed that it's dual-compound on the rear which rules it out, I think. The fact that the PR3's are dual compound is what's contributed to this issue.
I looked at FWR.co.uk and used their tyre size selector to bring up everything in stock in 160/60/ZR17, then I clicked on every single one and read the blurb.
Apart from PR1's and PR2's (I'm hesitant to go Michelin again after this) the only three single compound tyres that look like they might have been designed with high mileage in mind are:
    [li]Avon Storm 2 Ultra[/li]
    [li]Pirelli Angel ST (but I think these might be sport tyres that just happen to have longer life than other sport tyres, rather than compared to road tyres?)[/li]
    [li]Avon Storm 3D XM[/li]
I'm starting to despair a bit.
The last post was made 12 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 133.6 Kb
