CG 125 Accelerator pump
Commuter_Tim
PostPosted: 19:16 - 02 Apr 2014    Post subject: CG 125 Accelerator pump Reply with quote
I have a suspicion that the accelerator pump on my carb is fubar.
Does anybody know if the bike will run on a carb of the same spec but without an accelerator pump? (it seems the earlier models had no pump)
I bought one of these... https://www.ebay.co.uk/itm/New-Honda-CG125-Carburettor-Carb-Carburetor-NEW-/261420762074?pt=UK_Motorcycle_Parts_13&hash=item3cdde443da
but it turns out my CG has a pump!
I ride a Bandit 600... badly.
Commuter_Tim
PostPosted: 19:30 - 02 Apr 2014    Post subject: Reply with quote
Rob Fzs wrote:
It either squirts petrol at wide open throttle or it doesn't, if you haven't got a pump fitted it might just bog down for a couple of seconds if you wang the throttle open.
I appreciate the advice, it used to just bog down, now it bogs down, or stalls entirely when whacking on the throttle from idle. Sad
I know without the pump performance would suffer, but would leaving the pump cable disconnected and connecting the new carb prevent it from running at all?
I have a day off in a few days so I will be cleaning it then, I've took the new one apart, and doesn't seem too complex.
cheers
Commuter_Tim
PostPosted: 20:00 - 02 Apr 2014    Post subject: Reply with quote
Rob Fzs wrote:
check your air filter is clean and the jets in the carb are clear, pump really shouldn't make much difference.
Cool, I hope it is just that and not something more complex, as I'm Wrenchtarded.
Much Appreciated
von1papen
PostPosted: 22:56 - 02 Apr 2014    Post subject: Reply with quote
Check that the spring that holds the diaphragm in place is correctly placed.
When I bought my CG I had all sorts of carb problems, to find that the spring had been put behind the diaphragm which kept it permanently shut.
Honda CG125<Honda CM200< Kwak GT750 (SOLD) < BMW R65
The last post was made 12 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 48.94 Kb
