| Gavsta88 |
 Gavsta88 Renault 5 Driver
 Posted: 18:11 - 03 Apr 2014 Post subject: Bandit k2600s |
Hi Everyone,
Having a niggly problem with the bandit. When im going up to and over 8k revs the needle jumps around and it sounds rough when it does it. Almost like its spluttering/misfiring.
Does it in all gears, warm or cold. Sure it wasnt doing that over winter  |
| evilbond |
 evilbond Two Stroke Sniffer
| Az |
 Az World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 06:31 - 04 Apr 2014 Post subject: Re: Bandit k2600s |
| Gavsta88 wrote: | Hi Everyone,
The tacho takes it's signal from the black and yellow coil ground from the 2/3coil, which is grounded through the ECU so if the needle is jumping AND the engine is misfiring it's probably a fault on that wire, or in the loom, or (more likely) the red kill switch on the handlebars going faulty from vibes at 8k momentarily killing the ignition. It could also be the coil for 2/3 going bad (unlikely) or even the power feed to the coils (maybe a crack in the fuse).
I would start by changing the No3 fuse, because that's easiest.
Next I would check the coil spade connections especially the 2/3 coil to see if any are very loose.
Next I would un-plug the ECU and check the terminals aren't corroding.
After that I would strip down the kill switch and check the contacts. This is a favourite if people have got a lot of water in there from cleaning/jetwashing, or if the bar ends have been removed.
Here's a wiring diagram for aK4, it's very similar if not exactly the same. ____________________ a.k.a 'Geri'
| evilbond |
| evilbond |
| gavbriggs |
 gavbriggs Crazy Courier
| evilbond |
| gavbriggs |
| evilbond |
| evilbond |
 Posted: 18:10 - 12 Apr 2014 Post subject: |
Big discovery i think.
Found the exhaust can itself is rattling from inside, on removing it i've found the inner liner is loose. On tapping the exhaust you clearly hear a metal to metal rattle. Or at 5k rpm is rattles. Before or after not really noticeable.
https://i59.tinypic.com/2znsmrc.jpg
Inner freely slides out till near the end. End of the inner tube looks to be slightly damaged.
Need advise how to fix this or if i have to replace.
Thanks. ____________________ Bike: K2 Bandit 600S
Car: Astra GTC |
| evilbond |
The last post was made 12 years, 197 days ago. Instead of replying here, would creating a new thread be more useful? |
