Lexmoto XTRS, engine problems?
frankcom
PostPosted: 21:37 - 03 Apr 2014    Post subject: Lexmoto XTRS, engine problems? Reply with quote
Hello! I this is my first bike and I am clueless so please bear with me and my limited knowlage! Smile
I brought a 2011 lexmoto xtrs a couple days ago, and while riding it back home, about 50 miles in the thing just cut out on me, engine died and I had to roll it to a side road to park it up because when I tried to use the electric start it clicked, but the engine wouldn't start or turn over, and the kick start wouldn't even move. The next day a friend of mine took the left side engine casing screw off to turn the wheel thing (fly wheel?)behind it using his socket set and the pistons started to move after a little resistance, so I tried electric starting it and kick starting it again and the kickstart moved, and it seemed like the pistons were moving again but the engine just wouldn't start.
What should I do now? Anything I can try and check?
(on a side note I found that the choke is very stiff, cable might be stiff, but could that be related at all or just coincidence?)
Thanks all!
Lexmoto XTRS 2011
PostPosted: 21:54 - 03 Apr 2014    Post subject: Re: Lexmoto XTRS, engine problems? Reply with quote
Did it actually cut out suddenly with no warning, or did it start to struggle over a period of time (even a short one)?
Was there any ominous noise, for example the sound of a valve intersecting with a piston due to a bent pushrod?
Have you checked that there's oil in it?
frankcom wrote:
the pistons
Bit optimistic.
And did it turn over on the electric starter?
If it does, have you checked that you've got a spark? Take the plug out, ground it against the engine (hold it with gloves or insulated pliers) and see if it sparks as the engine is cranking.
Do the electrics work?
Have you checked if you've got some compression? When you've got the plug out, stick your thumb over the plug hole and turn the engine, feel for pressure.
moonzoomer
PostPosted: 22:08 - 03 Apr 2014    Post subject: Reply with quote
Was there any oil in the engine?
frankcom
PostPosted: 11:33 - 04 Apr 2014    Post subject: Reply with quote
No, it just cut out suddenly, no warning.
no noises or struggles either, it was entirely fine, then all of a sudden it cut out Sad
There is definitely oil in it, recently serviced too according to old owner.
At first it didn't turn over but I just tried again after spinning the fly wheel thing and the bike turns over and actually starts, but is making a rather disturbing clunking sound while running before cutting out, heres a video of what's happening: https://www.youtube.com/watch?v=W4iTzvJaAE8&feature=youtu.be
(Thinking about it I have never touched bike mechanics before so I probably can't do it myself)
I assume I have a spark because the engine is now starting, or should I still check?
All the electrics work,
and I can check the pressure now, I'll do that now!
Thanks for your replies all! Smile
Lexmoto XTRS 2011
PostPosted: 12:36 - 04 Apr 2014    Post subject: Reply with quote
Good job on the video. Thumbs Up You have a lovely voice. Wub
Are you sure? I mean, have you actually checked the dip-stick yourself? That sounds bone dry.
It's hard to tell from a video though, and I haven't wrecked enough engines to hazard a useful guess. Hopefully Pete or similar will come up with the goods, but I suspect that you may be getting familiar with your engine internals in the not too distant future. Sorry.
Hugh Farking Cant
PostPosted: 13:37 - 04 Apr 2014    Post subject: Reply with quote
That sounds like a big end shot to me .
Knocking is at same speed as crank revs.
It doesn't idle because the engine is now very unwell.
Were you thrashing it ;low on oil ?
Choke problem is least of your problems.
Nice vid. mind.
frankcom
PostPosted: 11:16 - 06 Apr 2014    Post subject: Reply with quote
Why thank you Embarassed
No, I'm pretty sure the oil is fine, however the dip stick appears to have been broken Mad
Ahhh okay, thanks for your help guys!
Lexmoto XTRS 2011
P.
PostPosted: 11:29 - 06 Apr 2014    Post subject: Reply with quote
That oil is not fine.
That is out of oil.
That is what a mechanic would call "fucked"
I would call it £50 and I'll take it, but only if you are nice. Time to buy a new bike. Neutral
blurredman
PostPosted: 12:06 - 06 Apr 2014    Post subject: Reply with quote
No matter what the previous owner says, Always do a full service yourself as soon as you get a bike/car.
P.
PostPosted: 12:18 - 06 Apr 2014    Post subject: Reply with quote
I check the oil whilst going over the bike... Shocked
That definitely sounds like melty melt.
Teflon-Mike
tl;dr
PostPosted: 13:02 - 06 Apr 2014    Post subject: Reply with quote
A bearing has colapsed.
Probably the big end.
Could you fix it?
Well, if you have two hands, two eyes, half a brain, a big bag of spanners, some space, and a bit of money.... probably.
Engine would have to come out of the frame, and be stripped down.
The big end is the bearing in the bottom of the con-rod. Sits on a pin between the two flywheels, attached through 'interferance fit'. Ie the holes are slightly smaller than the pin, which is rammed in with a couple of tons of pressure.
Means you need to get the crank professionally reconditioned, by chaps with big press and balancing equipment. (Have seen it done by old flat-cap-chaps, on old brit bikes with a fly-press and copper hammer; but bit of a dark art) Or buy new crank and con-rod assembly.
Rough guess, that bit, recond or replaced, about £150, up.
New gaskets, new main bearings, anything else the motor needs whilst you are in there? You could spent £500 on that engine, to make like new.
Pay a mechanic? Well it's probably a couple of days of work-shop time, if you gave them the engine 'loose' so, at £30 an hour, add another £250.
So, basically, to pay some-one to fix it, its probably well beyond ecconomical repair.
Get brave, get the spanners out, and try and DIY... well, doing a 'propper job', still probably boarder-line whether it's worth it, and you could do the job for less than you could get another bike, if at all.
Panic-Mechanics of desperation? There are plenty of chinky-bikes you might pillage a whole motor from, going for a couple of hundred quid or so; but you are into a mire of compatabilty issues, depending what they came from, and may have to get a bit crafty a bit quick, to match electrics, carbs and stuff... AND hope that motor you get has a bit more life in it than the one you have had before you got it.
Personally, I'd strip the motor you have; and get brave trying to follow the Haynes Manual for generic Chinese motorcycles.
If you are lucky, you will get away with little more than a gasket set and a few bearings, on top of a crank-recon, or if very lucky, you might find a half decent crank assembly 2nd hand on e-bay. And have a motor at the end of it, that's cost you as much as a 'take out' from chinky scrapper, but with more certainty it's 'good'.
There's no nice answer, I'm afraid, but what you got is scrap.
Crack out the spanners, and try make good; you got little to loose, and you are likely to learn a whole lot along the way....
Or, bung it up on -ebay, with a £50 start-price, "Spares or Repairs" cash in what you might from it, and go look for something else.
Fladdem
PostPosted: 21:30 - 06 Apr 2014    Post subject: Reply with quote
Sorry, bike sounds shagged, try an oil change, see what happens, if not look for a stolen recovered sinnis apache or something, nab the engine and then swap.
Also, bit odd, but you do a mean cover of Say It Ain't So. Thumbs Up
I'm also a Weezer fan.
PostPosted: 10:20 - 07 Apr 2014    Post subject: Reply with quote
Careful now. The Apache uses an OHC Suzuki copy. The XTR used the the OHV pushrod CG copy. XTR-S, dunno, there was some talk about a balancer shaft so who knows what they've been up to, but don't assume that all Chinese 125 engines are the same.
tomh
PostPosted: 10:51 - 07 Apr 2014    Post subject: Reply with quote
There should be a oil sight glass on the right hand engine cover. It does sound like it's been run on no oil though!
I've worked on a new 2013 Lexmoto XTR-S and that had the OHC Honda copy engine, not the CG engine.
wr6133
PostPosted: 10:55 - 07 Apr 2014    Post subject: Reply with quote
Don't start it up anymore you will just worsen shit.
I'd get it torn down and see what's been potatoed. A new engine costs about £330 and a used one from a breaking bike could be half that, so if parts to repair cost much more than about £150 I'd just replace the engine (less work).
Brand New 156FMI (you can use any 156FMI brand matters not)
https://www.ebay.co.uk/itm/125cc-Engine-Complete-to-suit-Sukida-Tough-SK125-5B-Brand-New-156FMI-157FMI-/221401010523?pt=UK_Motorcycle_Parts_13&hash=item338c87515b
Trawl eBay and you can probably get a used one from a breaking bike for half the price of the above one
Engine parts for yours
https://www.chinesemotorcyclepartsonline.co.uk/viewcat_3041_KS125-24.php
PostPosted: 11:14 - 07 Apr 2014    Post subject: Reply with quote
Hang on, let's figure out what engine is in there, exactly.
Typo? Or is it a copy of the CB engine?
WD Forte
PostPosted: 11:18 - 07 Apr 2014    Post subject: Reply with quote
Sounds serious to me
My initial thought was main bearing wiped
as big ends tend to sound 'sharper' and can be quiet at tickover then
come, in as you rev or put the motor on load.
Just a guess of course, thats all you get on any forum
It will need close examination whatever it is.
My lads 125 made a similar noise and when i whipped the side cover off
I could jack the crank up and down which confirmed the bearing had failed.
Fixable? yes but spendy and time consuming and not for the novice
A known good replacement would probably be your best choice IMO
Its all bit academic now but the damage may have been done by the POs
neglect and oil topped up prior to sale.
Re buying:
Trust no one
Some folk will lie their arses off to flog their old shite
even decent folk can talk utter bollocks without realising it
due to their lack of knowledge.
"Its been serviced" means nothing
bikers smell of wee
wr6133
PostPosted: 11:24 - 07 Apr 2014    Post subject: Reply with quote
It's a 156FMI there is an OHC and a OHV version. Either will fit his bike
tomh
PostPosted: 11:34 - 07 Apr 2014    Post subject: Reply with quote
It was a overhead cam engine, this eBay link has good photos of the engine.
https://bit.ly/1hT9MgQ
Any Chinese/Honda engine (125. 150 and 200cc) of the same design will have the same mounting points. Just be aware of the fact that although other engines will fit, they could have different charging systems, no rpm output (assuming the xtr one is mechanical) and adding the sight glass could mean getting to the dipstick is a problem.
WD Forte
PostPosted: 11:37 - 07 Apr 2014    Post subject: Reply with quote
Just noticed you appear to be in Bristol?
If you're not too far from Fishponds I could nip over and have a look,
suck air through my teeth and say helpful things like
"You cant get the parts mate" while consuming your tea and biscuits
bikers smell of wee
PostPosted: 12:11 - 07 Apr 2014    Post subject: Reply with quote
Ah, fair enough...
https://i.ebayimg.com/t/2013-LEXMOTO-XTR-125-23-XTR125-23-XTR125-COMPLETE-ENGINE-GEARBOX-ASSEMBLY-CARB-/00/s/MTIwMFgxNjAw/z/bxcAAOxy2FZSS-NG/$(KGrHqIOKo8FJ!RQneGpBSS-NF1Oc!~~60_12.JPG
... look like...
https://www.pakwheels.com/forums/attachments/bikes-3-wheelers/957762d1244943600-honda-cb-180-1975-honda-cb125s-blue-4025-5_tyu_pakwheels-com-.jpg.
As I understand it[*], the CG OHV pushrod was far more forgiving than the CB OHC for owners who neglected the frequent oil changes and checks.
If I were buying a used Chinese budget bike, owned and "maintained" by a typical Chinese budget bike owner, I know which one I'd prefer. Whistle
[*] Cometh the hour, cometh the Tef.
Meeky123
PostPosted: 22:14 - 08 Apr 2014    Post subject: Lexmoto xtrs 125 Reply with quote
Hi there new to this site, I have a lexmoto xtrs 125, I'm also having trouble with my bike, I can start it with the choke pulled down but soon as choke is pulled back up it stalls the bike was running fine before I dropped it on its side yesterday, I was also wondering if anybody knows wat size socket I need to remove the spark plug as the frame seems to be in the way any help would be much appriciated thank you
Dean meek
frankcom
PostPosted: 22:22 - 09 Apr 2014    Post subject: Reply with quote
thanks for all of your replies! Assuming I managed to get someone to just replace the engine entirely, would this probably fix my problem? I have been offered an engine from another XTRS and I know a guy who can fit it fairly cheap, so would this be a fix to go for?
Cheers guys!
Lexmoto XTRS 2011
frankcom
PostPosted: 22:25 - 09 Apr 2014    Post subject: Reply with quote
Could you fix it?
WOW. Basically I'm F*cked then, I'm pretty nervous about taking this thing apart but it might be worth a crack, thanks for the reply!
Lexmoto XTRS 2011
wr6133
PostPosted: 07:19 - 10 Apr 2014    Post subject: Reply with quote
Cheers guys!
How much is the engine and how many miles on it?
I'd go for this option though if the price is right. It's less hassle. Fit the engine yourself though, unless you are seriously feeble and lick windows in your spare time it's not a hard or lengthy job, definitely not worth paying someone to do.
The last post was made 11 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 139.05 Kb
