| slowlydoesit |
 slowlydoesit Could Be A Chat Bot
 Posted: 11:07 - 05 Apr 2014 Post subject: Which two-stroke oil for a Kawasaki KMX200? |
Based on the advice in this thread I decided to buy a trailie for the local back roads and - since G and others are always banging on about 2-strokes - I softened my opposition to smokers. Anyway, I managed to pick up a Kawasaki KMX200 from a friend for under £600.
It was fully rebuilt a few years back and has had very little use since due to my friend injuring himself shortly after buying it. As part of the rebuilt, all fasteners on the engine seem to have replaced with hex heads and frame was cleaned and repainted. It comes with loads of bits including a spare seat and most of another engine. Runs sweetly. Only problems are sticky front brake caliper and a pinhole in the tank. Other than that, looks good for the MOT, hopefully will be on the road in a couple of weeks.
So what two-stroke oil should I use? This fully synthetic scooter oil (Silkolene Scoot Sport 2) costs about £10 while the high performance version (Silkolene Comp 2 Plus) costs £16. Would a 25-year old KMX care either way? Should I just throw in any old 2-stroke bike oil from Aldi or some other chain? EDIT: I eventually bought Castrol 1L Power 1 Racing 2T from Amazon UK. This was cheaper for the same volume than the high performance Silkolene referenced above and because I'm an Amazon Prime member there was no postage to pay, so the total savings were significant.
PS proof that you can fit an entire dirt bike and a shed-load of parts in the back of a car (we did take the petrol tank off) thus saving a ton of money in delivery fees. Citroen Berlingo Multispace FTW!
https://i.imgur.com/szLi9oz.jpg
https://i.imgur.com/EVIXqRQ.jpg
| stuartt |
 stuartt World Chat Champion
| Mira |
 Mira Scooby Slapper
| Seb |
 Seb World Chat Champion
| slowlydoesit |
| slowlydoesit |
| stevo as b4 |
 Posted: 15:45 - 05 Apr 2014 Post subject: |
Anything fully synth would be my choice. Like many more recent stroker's the KMX runs a plated bore, and you want to preserve this as well as possible due to the costs of a re-plate or having a liner fitted etc.
Get some more pics up when it's together!  |
| _mjs_ |
 _mjs_ Could Be A Chat Bot
 Posted: 16:10 - 05 Apr 2014 Post subject: |
I'd go for the expensive stuff based on the old adage 'oil cheap, engines expensive'.
Cool bike  ____________________ Previous Bikes: 2006 Honda XR125L > 2003 Yamaha DT125R > 1996 Honda CB500
Current bikes: 1997 Kawasaki ZZR 600 E5 > 2006 Honda Varadero XL125V |
| slowlydoesit |
| andys675 |
 andys675 World Chat Champion
| stevo as b4 |
| slowlydoesit |
| slowlydoesit |
| bladerunner |
 Posted: 01:01 - 06 Apr 2014 Post subject: |
Check the grade ....Jaso b,c,d etc as that's how we'll the oil performed in tests to an international standard.....semi synth and the kmx will be happy....fully synth and you pay a bit more but tbh if your just off roading you'll probably use a couple of bottles a year. I stay away from car lube ( brand ) stuff just because I don't like the looks of it rather than bad experience ! I've run the kdx200 on scoot oil for 2 years without issue but have swapped to fully synth to see if it keeps the smoke levels down a bit....pre mix @30:1 on the kdx .....just make sure it's auto lube type stuff rather than the thicker per mix only stuff........oh the KDX last had a new piston 12 years ago and still going strong  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| slowlydoesit |
| stevo as b4 |
 Posted: 15:12 - 06 Apr 2014 Post subject: |
Good point, i tend to stick to known decent oil brands, Rock oil/Silkolene/Motul/Morris/Miller's etc.
I think you can get Morris and Millers synthetic and Silkolene on-line in 5ltr cans, for £30-40, and that would last you ages.
You need 1litre of engine oil or transmission oil for the gearbox, and the coolant system takes just over 1litre of coolant. Not sure if ready mixed is cheaper than buying antifreeze and mixing yourself, but it's less hassle.
If the bike runs hot off road then try back flushing the rad and cooling system, and straighten out any bent fins etc. You can use a 70/30% water-antifreeze solution which may help with cooling too. The 200cc has a marginal cooling system for serious off road use, and was considered less reliable than the 125 in this respect.
If you going to use it mainly off road, you'd probably like 14/48T gearing instead of the std 16/50T. Having said that my 125 could pull a higher final drive on the road, so when it's run in and dyno'd, I'm going to try 15/48T it adds a couple of mph to each ratio, and makes for 85mph/10000rpm.
I'm trying to get my 125cc finished for the Stafford show on the 26-27th. |
| slowlydoesit |
| stevo as b4 |
| slowlydoesit |
| stevo as b4 |
 Posted: 18:31 - 07 Apr 2014 Post subject: |
Hi, I'm afraid that I brought this one 98% fully restored, so the previous owner had the paintwork done.
It was a mismatch of panels I'm led to believe, and I think he used some reasonable condition panels whatever the colour, and then had them professionally filled/primed/sprayed by a good quality car bodyshop.
The bike was originally a white one, but over the years with dirtbikes, it's common to end up with mismatched panels. I have no idea what colour all the panels are under the nice clean white paint, and I don't want to off road it in case I find out lol!
You can still get new OEM front and rear mudguards, and side panels from some Kawasaki Dealers, definitely in Black, but I think green are still also available and maybe a few in white too, but probably not a full set.
Speak to Cradley Kawasaki, Peterborough Kawasaki or Cornwall Kawasaki for assistance. When I last priced up some new panels, it came to about £150 I think, which is still much cheaper than a full pro prep and re-spray of all the plastics.
You can obviously use pattern/aftermarket headlamp units, and guards if wanted which may well be cheaper? I heard dirtbike plastics don't take well to re-painting, but someone has made a nice job of the plastics on my 125 that's for sure.
Looking forward to seeing pics of you 200 soon! You never know I might become inspired to get off my arse then?  |
| slowlydoesit |
| dangerousdave |
 dangerousdave Traffic Copper
| dangerousdave |
The last post was made 12 years, 148 days ago. Instead of replying here, would creating a new thread be more useful? |
