| Coxyzxr |
 Coxyzxr Brolly Dolly
| moonzoomer |
 moonzoomer World Chat Champion
| stinkwheel |
 Posted: 21:14 - 05 Apr 2014 Post subject: |
I've seen people use air ratchets if they have a lot to do but in general, by the time you've got the thing out, it's not saved any time.
Periodically do them in lidl/aldi.
What's very useful are T-bar wrenches with a good heavy handle, you can spin them in and out. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
 Posted: 21:22 - 05 Apr 2014 Post subject: |
A weighted t-bar is handy but nowadays I do a lot of work with my cordless drill. I put either a 1/4" extension or a cut-off 3/8" extension in it and use sockets or hex driver bits. Just crack the fastener with a bar then whizz them all out. Same for re-installing except I wind off the friction drive and also slow right down just before the fastener seats. It's not hard to gauge it to a fraction of a turn with some practice. At work we have a small makita battery drill which weighs much less than my DeWalt or Works ones at home and is a handy small size. If you're going to buy one for extended use I'd suggest looking at the small makita ones. ____________________ a.k.a 'Geri'
| The Artist |
 The Artist Super Spammer
| davebike |
 davebike World Chat Champion
 Posted: 06:16 - 06 Apr 2014 Post subject: |
I use a cordless Driver a bit but not on fairing panels way to easy to crack one if not aligned you need the feel of a normal driver
Air ratchet is useful as is a palm 3/8" drive impact for engine strips
I use a t bar for assy don't use power it easy to break things !
Good rule of thumb is power to undo do up by hand
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| BTTD |
 BTTD World Chat Champion
| G |
 G The Voice of Reason
 Posted: 10:28 - 06 Apr 2014 Post subject: Re: Thoughts on cordless vs manual? |
Yes; I like a cordless drill for doing up and undoing longer fasteners before you get to the point where torque matters.
Of course, my usual trick is to spend five minutes looking for where I put it to save three minutes of time I could have done it manually .
For long engine case bolts, air box screws and so on it can save a good bit of time if doing it regularly.
And never had a problem with using power to do up - either set it to a low torque or just stop before it's tight . |
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
| Pete. |
 Pete. Super Spammer
| G |
| Hugh Farking Cant |
| Pete. |
 Pete. Super Spammer
 Posted: 14:14 - 06 Apr 2014 Post subject: |
That's fine, if you don't feel you have the dexterity to use a low-powered variable-speed portable tool then stick to Dave's method. Others can choose how they want to save their time. ____________________ a.k.a 'Geri'
| Hugh Farking Cant |
| G |
 Posted: 14:30 - 06 Apr 2014 Post subject: |
I just took it to be "Many blokes are complete idiots", which is certainly the truth . |
| Hugh Farking Cant |
| Pete. |
 Pete. Super Spammer
| trisers |
 trisers Scooby Slapper
| Coxyzxr |
 Posted: 19:20 - 07 Apr 2014 Post subject: |
Right,
Back at work today and given it some direct thought as I was working on bikes today and reading through replies here I definitely think it'll be a big time saver.
As I work in a main dealer we get LOTS of new bikes come in which always require the same things to be bolted on and assembled which always means fairings off then back on one stuff fitted, almost to the extent of it being slightly production lineish - so it's going to be a big help in that regard.
I'm looking at something lightweight and reasonably low torque like this or the one below;
These can have the toque set so low you wouldn't even strip fairing bolts. Plus the spindle lock on the snap on allows you to do the remaining torque up by hand.
I'm gonna grab buy one on Weds and see how it goes. Though the snap on is costly (obviously, it's snap on??) I still have to decide whether I can justify that cost.
Thanks for all the input.
https://www.toolhead.co.uk/wp-content/uploads/2009/02/bosch-gdr-10.8v-li-ion-impact-screwdriver-1.jpg
or this
https://i31.photobucket.com/albums/c392/tlee20/828A1921-60F1-473C-A745-26BC5357191B-6241-0000046A223A17AC_zps96338e70.jpg ____________________ **WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID ! |
| G |
| Hugh Farking Cant |
| Pete. |
 Pete. Super Spammer
 Posted: 20:27 - 07 Apr 2014 Post subject: |
It's got nothing to do with superior knowledge - it's what you're comfortable with. If you're employed then it's what your employer is comfortable with you doing. Personally, I have no problem using a power tool for fasteners and I can't recall ever stripping a thread using one to run up casing bolts.[/quote]
Casing bolts were not mentioned in my post..
It was specifically about fairing fixings.[/quote]
The horse is dead - you can stop your flogging now  ____________________ a.k.a 'Geri'
| DMCpro |
 DMCpro Traffic Copper
 Posted: 08:39 - 08 Apr 2014 Post subject: |
| Coxyzxr wrote: | Right,
or this
https://i31.photobucket.com/albums/c392/tlee20/828A1921-60F1-473C-A745-26BC5357191B-6241-0000046A223A17AC_zps96338e70.jpg |
The Bosch one pictured is a good tool not sure about the other one you posted (snapon?) but i use the Bosch every day even used it to assist with putting up a kitchen mainly use it on car and bike stuff though. ____________________ Honda CB-1, TS125X
VW Golf Estate |
| c_dug |
 c_dug Super Spammer
| Hugh Farking Cant |
 Posted: 18:51 - 08 Apr 2014 Post subject: |
| Pete. wrote: |
It's got nothing to do with superior knowledge - it's what you're comfortable with. If you're employed then it's what your employer is comfortable with you doing. Personally, I have no problem using a power tool for fasteners and I can't recall ever stripping a thread using one to run up casing bolts. |
The horse is dead - you can stop your flogging now [/quote]
Never flogged an animal in my life, cannot say the same for fitters .  ____________________ Remember; Someone on here always has a blacker cat. |
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
