Derbi GPR/Gilera SC, DT125 engine/carb fuel issue?
crazycat109
PostPosted: 19:37 - 03 Apr 2014    Post subject: Derbi GPR/Gilera SC, DT125 engine/carb fuel issue? Reply with quote
hi all, i have a 125cc sports bike with a 2t dt125 engine with what i think is a fueling issue.
problem is that it wont pull in 6th gear it actually decelerates so its pretty useless. the bike runs fine in lower revs/gears.
the previous owner has fitted a full arrow exhaust system to the bike thus leading me to believe that it maybe running lean?
my question is will increasing the main jet from #210 to #220 and 1 notch down on the needle potentially fix this? yes/no, not enough?
carb model is a Mikuni TM 28-92/1.
thanks for reading. adam
SQL
PostPosted: 20:09 - 03 Apr 2014    Post subject: Reply with quote
GPR?
crazycat109
PostPosted: 20:12 - 03 Apr 2014    Post subject: Reply with quote
SQL wrote:
GPR?
pretty much. its the gilera version
SQL
PostPosted: 20:14 - 03 Apr 2014    Post subject: Reply with quote
crazycat109 wrote:
SQL wrote:
GPR?
Check this out first
https://www.125ccsportsbikes.com/forums/index.php?showtopic=69663
Has manuals and all sorts
crazycat109
PostPosted: 20:26 - 03 Apr 2014    Post subject: Reply with quote
thanks but i am already aware of this post.
i just want to know if rejetting will help the bike pull in top gear
i appreciate your reply though
SQL
PostPosted: 21:56 - 03 Apr 2014    Post subject: Reply with quote
Possibly however the first thing I would check is what gearing you have is it stock??
what speed do you hit on the clocks in 5th?
crazycat109
PostPosted: 00:05 - 04 Apr 2014    Post subject: Reply with quote
ive got 1 less tooth on front and reaches about 70/75mph in 5th at 10k rpm
crazycat109
PostPosted: 22:05 - 05 Apr 2014    Post subject: Reply with quote
think i found the problem :/ the previous owner has drilled 4 12mm holes in the air box which i think is making it run lean. took the carb off anyway and its already up jetted to 220.
anyway ive fitted some carbon fiber reeds to help and gonna get a new air box or plastic weld the old one. if this don't cure it then maybe a 230 jet.
or seeing as these bikes supposedly cant pull top gear well i might just be too heavy for the bike (15stone)
bought this bike from the triumph dealer in Blackburn, you think they would've spotted the holes when they check it over
SQL
PostPosted: 00:59 - 06 Apr 2014    Post subject: Reply with quote
Also I believe these airboxes never did seal properly, I intend on using bathroom sealant to seal mine
The last post was made 12 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 58.84 Kb
