| scoobiemandan |
 scoobiemandan Renault 5 Driver
 Posted: 04:17 - 06 Apr 2014 Post subject: How do I compression test an NSR125? |
Hi,
Very new to bikes so excuse my ignorance. Recently bought me an NSR125 with little history and no idea whether a top end rebuild has ever been done. It's currently sitting at 21,000 (possibly km as an import). Don't have any running issues at present but would like to check for piece of mind.
Done some searching but found different answers which never really helps from a newbie perspective. Anyways, could someone please explain the steps (easy for an idiot to understand) on how to do a test? Also, is there any particular bit of kit I require or is the following okay for the job?;
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199553_langId_-1_categoryId_255216#tab3
Thanks for reading peeps  ____________________ IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport |
| Fisty |
 Fisty Super Spammer
| scoobiemandan |
 Posted: 05:43 - 06 Apr 2014 Post subject: |
I suppose I asked for that
Thanks but do I need to ground the spark plug, if so, how? Do I need to open full throttle? Cold engine or hot engine? ____________________ IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport |
| jeddy11 |
 jeddy11 Traffic Copper
 Posted: 07:47 - 06 Apr 2014 Post subject: |
No its a compression test that is all to make sure your cylinder inst leaking air pressure so take a plug out and pull the ht leads off the other plugs(if there was any) as said plug the compression tester in the hole then turn the bike over your not trying to start the bike up so no throttle etc needed as the engine turns over your compression tester will go up and a reading will be made.
You will now know if your pistons/rings/cylinders are good or not.. ____________________ Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!! |
| scoobiemandan |
 Posted: 07:52 - 06 Apr 2014 Post subject: |
Thanks Jedda but how is air gonna enter the chamber if the throttle isn't open and couldn't I damage the ignition system without grounding the ht lead?
Just wanting to do this the safest and best way  ____________________ IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport |
| weasley |
 weasley World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 09:13 - 06 Apr 2014 Post subject: |
| scoobiemandan wrote: | Thanks Jedda but how is air gonna enter the chamber if the throttle isn't open and couldn't I damage the ignition system without grounding the ht lead?
Just wanting to do this the safest and best way  |
Yes, open the throttle all the way, let it pump free air.
Air will get through the carb with the throttle closed, same as it does when the engine's idling, with the throttle shut; its never totally shut, its not a vacuum seal, but compression test will be better WOT.
If spark plug isn't grounded, then spark don't jump. That's all. There's no circuit, so electric wont flow. Shouldn't damage anything.
If you are really worried about it and want to see sparks; earth spark plug with a a jump-lead from the spark plug threads to the swing arm pivot or other convenient earth point. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| scoobiemandan |
| P.addy |
 P.addy Red Rocket
| Kickstart |
 Kickstart The Oracle
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
| scoobiemandan |
| Hugh Farking Cant |
| stirlinggaz |
 stirlinggaz World Chat Champion
| alains |
 alains World Chat Champion
| scoobiemandan |
 Posted: 17:22 - 07 Apr 2014 Post subject: |
We're moving to morrow so things are a bit up in the air at the moment but I shall be redoing the test and having throttle full open and see if that makes a difference and do it maybe three or four times to get an average. I'll report back when I do.
I got a nephew who's just rebuilt his Aprilia engine so I've already told him I'll be accosting him when the time comes  ____________________ IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport |
| c_dug |
 c_dug Super Spammer
 Posted: 17:29 - 07 Apr 2014 Post subject: |
A two stroke rebuild is easy-peasy as long as you can follow some instructions  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| scoobiemandan |
The last post was made 12 years, 207 days ago. Instead of replying here, would creating a new thread be more useful? |
