Which is the idle control screw?
scoobiemandan
PostPosted: 10:50 - 06 Apr 2014    Post subject: Which is the idle control screw? Reply with quote
Stole the following picture from Google but am assuming it's the right part. I'm wanting to know which is the idle screw? When I got the bike yesterday it was idling very low and almost cutting out so the guy ran it too his mechanic to adjust. However, started it this morning and after initially idling at around 1400revs a blip of the throttle saw it rise and stay at 3000revs?
Not sure if this is because the engine's cold or whether the adjustment yesterday was fine but then after running it, perhaps I cleaned the sytem through a bit??
Choke is closed by the way Wink
https://i136.photobucket.com/albums/q193/ri_powell/NSR125/IMAG4807.jpg
IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport
Teflon-Mike
tl;dr
PostPosted: 11:05 - 06 Apr 2014    Post subject: Reply with quote
On on the left of pic, bigger screw, under the throttle slide is the idle set screw.
Its just a pointy bolt, throttle slide falls onto tapered bit, more you screw it out, lower slide falls before it stops.
When adjusting, LIFT the throttle slide, twist idle set 1/4 either way, let slide back down onto stop, and re-check idle speed.
1/ Means that you dont end up screwing teh screw into the soft alloy of throttle slide if its a bit sticky.
2/ means actual idle speed has to settle to new stop position if slides a bit stickly.
scoobiemandan
PostPosted: 11:13 - 06 Apr 2014    Post subject: Reply with quote
Mike's on a roll today....cheers pal Smile
The last post was made 12 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.09 - MySQL Queries: 13 - Page Size: 37.89 Kb
