Super unleaded CG125
Tamsin
PostPosted: 16:08 - 06 Apr 2014    Post subject: Super unleaded CG125 Reply with quote
I put a gallon of super (BP ultimate) in the CG this afternoon, was thinking that the fuel in it might be a bit old and maybe a tad stale so a boost of octane might do it a little bit of good.
the results actually astonished me, it was so much smoother, more responsive and less vibey.
Question being, on something as basic as the CG engine should using super make any difference at all? I cant see why it actually would, unless the fuel that was in it was actually really quite stale...
PostPosted: 16:09 - 06 Apr 2014    Post subject: Reply with quote
No, it won't. Thumbs Up
Irn-Bru
PostPosted: 16:10 - 06 Apr 2014    Post subject: Reply with quote
Wasting your money, but your choice.
Tamsin
PostPosted: 16:16 - 06 Apr 2014    Post subject: Reply with quote
thats what I thought.
Im gonna put it down to old fuel in the bike then Laughing
PostPosted: 16:17 - 06 Apr 2014    Post subject: Reply with quote
Doubt the CG needs the octane rating on conventional unleaded, let alone super unleaded.
With fuel octane rating, if the rating of the fuel is too low then you risk serious engine damage, but higher than required will give zero benefit (except on engine which can adjust the ignition timing and / or turbo boost based on the feedback from a knock sensor - virtually no bikes do this). Note that higher octane fuels tend to have a marginally lower energy rating by volume (ie, the additives to increase the octane rating have a low energy content), although with road fuels the difference is irrelevant.
However suspect you were using one of the premium fuels on which they make various other claims as well as the increased octane rating.
Ran my car on the Shell optimax / vpower / nitro / whatever they are calling it this week fuel last month as an experiment. It did seem smoother, but no more powerful and it made no difference to fuel consumption at all.
fatpies
Placebo
Tamsin
PostPosted: 16:22 - 06 Apr 2014    Post subject: Reply with quote
it made a significant difference, previously between 25-30 it felt like it was trying to shake itself to pieces but having put the ultimate in it felt entirely smooth and stable in that range....
I've not gone above 35 on it yet (20 and 30 limits all the way to work) so dont know if there would be any difference at higher speeds...
definitely not a placebo, but I'll stick to regular from here on.
PostPosted: 16:31 - 06 Apr 2014    Post subject: Reply with quote
Same gear/throttle opening/road etc. etc.?
Do you understand the difference offered by higher octane fuel?
They probably run it on 91 Octane in Japan with no changes, so it's already being spoilt by the 95 over here.
Tamsin
PostPosted: 16:38 - 06 Apr 2014    Post subject: Reply with quote
Simply put, the higher the octane, the higher along the ignition curve that the engine can fire the spark before it starts pinking and therefore a greater potential explosion and power output, assuming - as said earlier - that the vehicle has the ability to adjust its ignition timing as per electronics or the timing is set to be using it.
Conversely when fuel starts going stale the octane rating begins to reduce, alongside the combustion efficiency. This is my theory as to why its made such a difference that the fuel in the bike was old and going stale - I know it had been sat unused for a few months so its quite possible the fuel was beginning to get a bit elderly
PostPosted: 16:41 - 06 Apr 2014    Post subject: Reply with quote
Precisely, try filling up with 95 RON. I'd be stunned if fuel had dropped to the level where your bike would start pinking in only a few months.
Tamsin
PostPosted: 16:43 - 06 Apr 2014    Post subject: Reply with quote
at least a few months, it'd only done about 60 miles since the MOT last year
PostPosted: 16:44 - 06 Apr 2014    Post subject: Reply with quote
It was probably crap fuel then. Laughing They do put stabilisers in it to stop it deteriorating.
PostPosted: 16:49 - 06 Apr 2014    Post subject: Reply with quote
The CG125 probably thinks it is being given a treat running on normal 95 RON unleaded. If the octane rating of the fuel had dropped enough for detonation to become a problem then you have a fair chance of having major engine damage (eg, hole burnt in a piston).
That said, one way to increase the octane rating of a fuel is to make it burn more slowly (ie, the ignition fires while the piston is still going up, so cylinder pressure increase both from the piston going up and the fuel starting to burn, and if that pressure gets too high you get detonation). Entirely possible that a slower burning mixture might be smoother, even if giving less power.
Tamsin
PostPosted: 17:26 - 06 Apr 2014    Post subject: Reply with quote
all makes sense. Thanks for the input guys - largely confirmed my feelings
Thumbs Up for everyone Cool
stevo as b4
PostPosted: 20:31 - 06 Apr 2014    Post subject: Reply with quote
I like high octance fuel 98/99RON etc, as IMO it should safely allow me to run a few more psi on my blower, and more aggressive noises from the EWG and screamer.
I'm not sure what boost level is considered as maxing out a T28 turbo (200SX S14 spec with the 0.64AR exhaust housing)? Some say 15psi, some say it's good for 18psi?
covent.gardens
World Clap Champion
PostPosted: 21:12 - 06 Apr 2014    Post subject: Reply with quote
I used to treat my CG to a full tank of premium fuel every few months, never planned, just when I felt like it. The way I see it, the CG gets about 100mpg and has a small tank, so it doesn't cost much to fill with premium, and the engine benefits by running on that fuel for a relatively long time.
I'm certain the octane is irrelevant but the advertised cleaning properties and other benefits of premium fuel, well, who knows, might have been worth it, probably not!
Bunny Lingus
PostPosted: 21:42 - 20 Apr 2014    Post subject: Reply with quote
I use high octane in all my little bikes with iridium spark plugs. The one that seems to benefit most is my custom Honda Cub, possibly due to the fact that it is sooo slow. Hills are where it shows up most. Muswell Hill in north London is a particular bastard & riding up it on a Cub with a queue of cars behind ain't funny. There is a big step between 2nd & 3rd gear on a Cub - in 2nd, the bike is screaming for mercy but change up to 3rd & acceleration just dies. I have found that if I don't get stuck at the lights at the bottom of the hill I get nearly to the top before I have to change down if I use high oct. The blokes on the Cub forums recommend high octane/iridium plugs & some of 'em advance the ignition by 3deg by welding a blob on the geny & grinding off the old one.
Bunny Lingus & The Flipside Faggots
Pigeon
PostPosted: 22:11 - 20 Apr 2014    Post subject: Reply with quote
On my 125 bunging in Shell V-Power always made the bike seem to have more torque.
But for a long while I was only filling up once a month (275 miles), so its quite likely that newer fuel was enough of an improvement to be noticed.
That said, I tried the Shell Max Economy stuff, that's supposed to increase mpg or something. And that wasn't great, like having the front brake stuck on.
I stick the cheapest stuff in the SV as the manual talks about 85 ron, or 79 ron. Something really low. Plus I don't notice any difference where on the 125 I did.
PostPosted: 22:23 - 20 Apr 2014    Post subject: Reply with quote
On every single bike, I've never noticed any difference... at all.
kramdra
PostPosted: 22:53 - 20 Apr 2014    Post subject: Reply with quote
Loose bolt somewhere. Its now fallen out Laughing
Probably lots of rust, water and shit in the tank if your noticing that it runs better full - drain some out and check inside.
I assume the premium fuels achieve higher octane by increasing ethanol content or similar additives, I would much prefer a lower octane Thumbs Up
PostPosted: 23:10 - 20 Apr 2014    Post subject: Reply with quote
Watch out for the octane requirements that are listed. Some will give you the US octane requirement which will be a PON figure. US 90 octane would be roughly the same as UK 95 octane (UK and Europe uses the RON figure).
smegballs
PostPosted: 23:46 - 20 Apr 2014    Post subject: Reply with quote
Obviously the CG is made for use all over the world, as I expect Kickstart is right about it being having a treat on 95. Anyone know if 3rd world cg's actually run lower compression or anything?
Bunny Lingus
PostPosted: 05:27 - 21 Apr 2014    Post subject: Reply with quote
No but shit fuel & low power don't trouble the boys in Karachi -
https://www.youtube.com/watch?v=YZqlEnwnNYM
https://www.youtube.com/watch?v=PVNoJPouZSc
https://www.youtube.com/watch?v=becIozwYjjI
smegballs
PostPosted: 13:23 - 21 Apr 2014    Post subject: Reply with quote
Bunny Lingus wrote:
Skills with a z! He gets it up so effortlessly.
kramdra
PostPosted: 15:33 - 21 Apr 2014    Post subject: Reply with quote
In a puddle, wearing sandals Cool
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 128.9 Kb
