Crosswinds
Tamsin
PostPosted: 18:29 - 06 Apr 2014    Post subject: Crosswinds Reply with quote
So i'm beginning to get a hang of this two wheel malarky. Trip to and from town today was probably my best run to date all told.
Still a bit nervous of speed - not gone above 35 yet (but aside from one short 40mph stretch) its all 30/20 limits. Today though I had a new experience - a very strong crosswind gust which threw me for a minute - what is the best way to deal with them?
hedgehugger
PostPosted: 18:32 - 06 Apr 2014    Post subject: Reply with quote
Relax.
If you fight them, it just makes it harder to control.
wr6133
PostPosted: 18:36 - 06 Apr 2014    Post subject: Reply with quote
Pitch the mainsail and make use of the wind.
Teflon-Mike
tl;dr
PostPosted: 18:42 - 06 Apr 2014    Post subject: Re: Crosswinds Reply with quote
Same as anything that will sway you from your charted course; dont panic, let the bike find its balence, apply gentle correction.
Dont start tensing up every time you approach a gap between buildings, or anything 'predicting' the bike veering; just go with the flow.
And remember, motorcycle gains stability from motion; faster you go, more stability it gets.
Doesn't mean open the taps and blast into it... but, dont suddenly throttle off, because of a bit of buffet; that will help de-stabilise the bike and see you veer more; so be confident; trust the bike, relax ride through, apply correction as necessary to hold course, and go with the flow. Nice and calm and confident.
CaNsA
PostPosted: 18:56 - 06 Apr 2014    Post subject: Reply with quote
Lean into crosswinds.
mentalboy
PostPosted: 18:59 - 06 Apr 2014    Post subject: Reply with quote
As above but tailor it to the type of sidewind.
If you're only getting blown about passing gateways in hedges then move away from the middle of the road when you see a gate and let it blow you more towards the middle. For long stretches you'll need to brace against it a bit more however on stuff like motorways it can just be a pain in the butt - lean into the gust quite happily and then shit bricks when the wind suddenly dies back and leaves you bracing against nothing or let it blow you into the other carriageways, Hobson's choice!
All part of the 'fun' of biking Wink
Make mine a Corona.
Mumrah
PostPosted: 19:32 - 06 Apr 2014    Post subject: Re: Crosswinds Reply with quote
Well done! You'll be hitting the max speeds in no time and wishing you could push it more Wink
Christoffee
PostPosted: 20:49 - 06 Apr 2014    Post subject: Reply with quote
Great advice above. The wind scared the life out of me and everything above is solid noob advice.
It's like everything. Just keep practicing. Don't put off a ride because it's windy. Just crack on. It was a really windy winter and now I don't mind the wind at all. Just like I don't mind the rain. Of going flat out! I hit 70 once!
Bike: CBF125
Christoffee
PostPosted: 20:56 - 06 Apr 2014    Post subject: Reply with quote
Bike: CBF125
Tamsin
PostPosted: 21:45 - 06 Apr 2014    Post subject: Reply with quote
Cheers. I am gaining in confidence and experience daily but still have a lot to learn and its good to ask these questions Very Happy
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Ben90
PostPosted: 21:54 - 06 Apr 2014    Post subject: Reply with quote
I hit a crosswind today as well, I found that I was leaning into it to stay in a straight line - a strange experience as you feel as if you should be turning!
Yamaha FZ6 S2
gavbriggs
PostPosted: 22:04 - 06 Apr 2014    Post subject: Reply with quote
Pass your test and then get a massive bike and use brute force, works for me.
I do remember however when I was 16 and on a Simpson 50 'magpie' (I shit you not!) a stretch of 40mph road is open to the pennines in the distance and not a deal between. Wind gusts a fair bit and as I cleared the houses and hit the exposed stretch I was almost horizontal trying to counter the wind at full throttle and could only have been doing 20mph.
I did shit my self a bit but it taught me to ride the wind!
Pigeon
PostPosted: 22:35 - 06 Apr 2014    Post subject: Reply with quote
Can't add anything useful to what everyone has said.
But just that being calm is 80% of the battle won......except battle's the wrong word, you're not in a fight, you're just outside Smile
On my 125 I actually really liked the wind, the crazier the better. Found the whole being blown about exhilarating.
The 70-80mph winds we had last winter were well above the top speed of my bike. Started off by leaning into the wind, then a knee out, then hanging off a bit, then leg+arse+upper body all off the side.
At the same time I had the scene from Willy Wonka with the boat running through my head.
There's no earthly way of knowing, which direction we are going...
mmm, this probably isn't helping.
covent.gardens
World Clap Champion
PostPosted: 22:37 - 06 Apr 2014    Post subject: Reply with quote
Learn about conscious countersteering. When you encounter a gust that blows you to the right you can simply move the left bar forward and you're back on course again almost instantly. Once you're used to it you will automatically respond to unintentional changes of course by countersteering and you'll find you stay in a relatively straight line. It's far more responsive and precise than leaning.
ScaredyCat
PostPosted: 23:34 - 06 Apr 2014    Post subject: Reply with quote
This is totally wrong. Ignore it. Just because you've recently become aware of countersteering does not make it a panacea for everything.
Do not try and fight it you'll make it worse not better. Lean into the direction the wind is coming from slightly it will help. Be very aware of gaps in things like hedges, where there are gates or trees/bushes have died. You'll be pootling along quite nicely and the wind will rush through these gaps and push you. Don't grab at the bars, use your knees to grip the tank and squeeze.
I have to deal with this a lot on my commute, the more you have to deal with it the easier it gets. The worst time is if there's nothing to protect you for long stretches - it can become very tiresome.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
covent.gardens
World Clap Champion
PostPosted: 23:53 - 06 Apr 2014    Post subject: Reply with quote
It is not wrong, and you are pathetically looking for any excuse to continue to rate me down after the Hetzer thread.
"Recently" got used to countersteering? Try two and a half years ago... Rolling Eyes
I did not say "Fight it". You can relax on the bike and make subtle adjustments to the bars (countersteer) to stay straight. This avoids the problem mentalboy stated:
I'm afraid I've got to laugh at you for saying countersteering is wrong and leaning is right, when leaning causes countersteering, the only difference with conscious countersteering is you don't get caught with your bodyweight in the wrong place when the wind changes.
As you find it very tiresome and struggle with wind then it rather suggests you're doing something wrong, not me. I don't have any trouble.
ScaredyCat
PostPosted: 00:02 - 07 Apr 2014    Post subject: Reply with quote
This has nothing to do with the Hetzer thread although you deserved the redundant ratings for being repetitive hence the redundant rating.
Conscious counter steering (as opposed to counter steering that occurs when cornering) is an advanced technique - certainly above 'just got on a bike' level of riding. You're telling someone who's barely ridden to use it? That's wrong and easy to fuck up if you're not used to riding a bike.
covent.gardens
World Clap Champion
PostPosted: 00:08 - 07 Apr 2014    Post subject: Reply with quote
Sure it has nothing to do with it, you just so happen to have given me redundant ratings all day when you never have in the past 2 years.
Conscious counter-steering is hardly rocket science, and should NOT be thought of as an advanced technique, and I couldn't disagree more, it should be taught at an early stage, preferably at least mentioned during CBT, so beginners know methods exist to exercise more precise and immediate control over the bike. As for it being dangerous to merely mention its existence to a newbie... Rolling Eyes *Sigh*
ScaredyCat
PostPosted: 00:20 - 07 Apr 2014    Post subject: Reply with quote
You've had many redundant ratings from me, because you tend to go on and on about the same thing over and over.
Conscious counter-steering is hardly rocket science, and should NOT be thought of as an advanced technique, and I couldn't disagree more, it should be taught at an early stage, preferable at least mentioned during CBT, so beginners know methods exist to exercise more precise and immediate control over the bike. As for it being dangerous to merely mention its existence to a newbie... Rolling Eyes *Sigh*
It is an advanced technique if you're a new rider. It's also not dangerous to mention it to anyone - I didn't suggest it was. It's just dangerous to suggest trying it to someone with little experience of being on a bike who may well go out and try it without having anyone to explain it properly, what to expect and what will happen.
I agree countersteering isn't necessarily something you pick up on naturally, but it's easy to understand and piss easy to do once you're shown how.
My emphasis obviously.
covent.gardens
World Clap Champion
PostPosted: 00:32 - 07 Apr 2014    Post subject: Reply with quote
I did not say they should rush out and try it. My exact words were: "Learn about conscious countersteering". How can they begin to learn if they don't even know about it? I delayed using this useful technique when I was new because I did not know about it.
There's plenty of good YouTube videos to show you how. What is your point by bringing this older post of mine up? I agree with it completely. I never said you had to be shown it by an instructor, if that's what you are trying to get at; far from it.
Do you now acknowledge that conscious countersteering is useful in dealing with wind?
PostPosted: 01:57 - 07 Apr 2014    Post subject: Reply with quote
Crosswinds, meh. I was blown from the middle lane after overtaking a car on the motorway onto the hard shoulder in one of those storms we had a few weeks ago.
That was a scary moment.
But advice above is sound, you get used to the winds and leaning into them helps.
dydey90
PostPosted: 09:49 - 07 Apr 2014    Post subject: Reply with quote
My worst experience in a crosswind is travelling along a road that's slightly higher than the open country around it, with a perfect 90° wind hitting me, my arse hanging over the right side of the bike to stay straight and the car behind me getting pissed off, attempting to drive down my exhaust thinking "But why is he only going at the speed limit". Brick Wall
Still, steady winds are easy enough to deal with. It's the blustery gales that seem to change speed and direction at random that cause intense sphincter activity.
Bendy
Mrs Sensible
PostPosted: 11:15 - 07 Apr 2014    Post subject: Reply with quote
Wing down into wind and opposite rudder to counteract the yaw. Land on one wheel and ease it onto the other. Keep the stick into wind so you don't get blown over when taxying.
Oh you mean on a bike? Go faster. More momentum Or is it inertia? Never sure which is which. Don't pop wheelies.
Teflon-Mike
tl;dr
PostPosted: 15:08 - 07 Apr 2014    Post subject: Reply with quote
Dont try 'counter-steering' on a tiddler.
Keith Code has made a fortune selling this one technique to numpties who cant be bothered to learn to ride a motorbike properly, but want a quick fix to go kwik... mostly in america... where it tends to works as they treat 750's as learner-bikes.
Its not particularly appropriate and its not necessary on a 125, as a method of gaining a sort of 'servo steering effect' to help make faster direction changes, which can be useful on a faster, heavier machine, but even there, not really in anyway appropriate to reacting the sustained 'yaw' pressure of a cross-wind on a lightweight.
If you wish to study Keith Code 'lore' I suggest you go to source, rather than oft repetatition distorted re-iterations offered by others; and read his books, rather than the videos, as they too rather pander to the impatient too, while the books, DO actually give some more enlightenment of why, where, and how his suggested techniques MIGHT be helpful... but don't take it as the absolute and only truth, a LOT of it is dummed down for Americans, and a lot of his 'theory' is more promoting his religion of 'scientology' than explaining actual 'science' of motorcycles. (Also worth noting he's essentially a motorcycle journalist who has exploited the media and publicity far more successful than he ever has a motorcycle. Even his 'super-bike-school' wasn't even his idea!)
But, for UK Learner; I would recommend DSA's 'Official Motorcycling' as a far better starting point, and if you want a heads up on 'advanced riding', the follow on book, "Motorcycling The Essential Skills" which could as easily be titled 'Road-Craft for Beginners', and concentrates on basic technique and discipline, good practice, common sense and thinking for yourself, rather than mantras and marketing, that wrongly applied can get you into trouble more easily than they can help you ride 'better'.
The last post was made 12 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 137.2 Kb
