| MattJ |
 MattJ World Chat Champion
 Posted: 14:47 - 03 Apr 2014 Post subject: Brown stain on intake valve |
The engine is from a KTM500EXC and has barely been used. It's going in a single seat race car that we're building at uni and the engine has been run in and then only started a few times after that. It's possible that the injector has been positioned wrongly when it has been started up a few times, but would that cause that? It doesn't rub off, it seems to be stained on there.
https://s14.postimg.org/5hak7hc9d/DSC_0923.jpg
Any ideas? |
| mentalboy |
 mentalboy World Chat Champion
| weasley |
 weasley World Chat Champion
 Posted: 16:09 - 03 Apr 2014 Post subject: |
It looks like lacquering, probably from fuel (but potentially from oil, if there is a crankcase breather fed into the intake air).
For fuel it would mean there is, or has been, opportunity for liquid fuel to sit on the back of the valve when it is shut (and hot). This could be down to poor injector location, spray pattern, injection timing, poor injector needle seating, poor airflow, over-fuelling or any other factor that would allow fuel to settle or pool on the valve tulip (rather than atomise and stay in the airflow). Or it could just be crap fuel.
If there is a crankcase breather into the intake air, oil mist can carry over but this really doesn't look like classic inlet valve fouling from oil, which tends to be washed away by the fuel spray anyway.
Lacquers like that can be pretty stubborn to shift, although they are often more a cosmetic issue than anything (although they can act as a base for further deposition). ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| MattJ |
| Ariel Badger |
 Ariel Badger Super Spammer
| gavcarter |
 gavcarter Could Be A Chat Bot
| stevo as b4 |
| Ariel Badger |
| sickpup |
 sickpup Old Timer
| gavcarter |
| stevo as b4 |
| bladerunner |
 bladerunner World Chat Champion
 Posted: 22:32 - 06 Apr 2014 Post subject: |
Agreed the modern thought is mirror polishing causes MORE drag on the incoming charge .....think of the dimples on a golf ball,they reduce the amount of air drag and improve distance covered vs a smooth ball of otherwise identical dimensions and weight  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
The last post was made 12 years, 210 days ago. Instead of replying here, would creating a new thread be more useful? |
