Please help Yamaha YBR 125 2007
Mantas1992
PostPosted: 11:41 - 07 Apr 2014    Post subject: Please help Yamaha YBR 125 2007 Reply with quote
Hello everyone,
I bought used non runner Yamaha, which been standing for two years. So I have cleaned the tank, fuel injector, air filter and changed oil and I cant get it started. When turning ignition i can hear tick in the fuel pump inside the tank, but there is no fuel coming to fuel injector from tank so should i replace fuel pump?
p.s. on fuel injector there is brass screw I cant get it out any tips?
gavcarter
PostPosted: 11:44 - 07 Apr 2014    Post subject: Reply with quote
unplug the fuel hose from pump and try and start. Fuel should come out ( obviously).
If it does then your problem is after the pump ( check injector - if that works probably not a fueling problem)
Teflon-Mike
tl;dr
PostPosted: 13:09 - 07 Apr 2014    Post subject: Reply with quote
This is why I try and stick to stuff with carbs. However.
Injection systems are electrikery; the actual injector, a mechanical device, is least likely to be the problem... least at this stage.
What is more likely, is that the control electronics dont think the engine needs any petrol, so isn't telling the injector to squirt any.
There should be a throttle position sensor that tells the ECU how wide open the throttle letting air in is; and thses tend to wear, and or get gummed up, or go out of calibration; then there is the trigger on the crank, / cam to tell the ECU when the engines on the suck stroke; THEN there may be the self tuning 'lambda' sensor in the exhaust to tell the ECU whether to up or down the mixture strenth. Possibly one or two others.
FIRST port of call, get the book for the bike.
Then, look at the sensors, and the electrical connectors, and clean every-bludy thing, like book says.
Do simple checks first, like compression and spark; then start worrying whether the injector may be gummed up.
However... quick caution; laid up bikes; engines last thing that needs attension. Before you try to make it go, make sure it will stop! Service brakes; check tyres, steering and suspension. THEN worry whether it makes rorty-nioses.
So, get the book, do all the stuff it says under 'service' items; then follow fault finding tree for the injection system.
The last post was made 12 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 37.43 Kb
