Problem with my cbf 125...any help?
zeano182
PostPosted: 12:58 - 07 Apr 2014    Post subject: Problem with my cbf 125...any help? Reply with quote
hey guys
yesterday my bike started makin a funny electrical noise when i was riding it, so i pulled over into the petrol station and turned the key off. To my suprise the bike was still trying to start, even with the key out. Its like its constantly tryin to fire up....took it to the garage but they cant look at it till tommorrow. but they suested its probablym water caught in it.
any ideas anyone else had this problem? when im riding its trying to fire up and when i stop it still trys to fire up. only when i rev it over 6000rpm does it stop for about 5-10 seconds.
Thanks zeano
arry
PostPosted: 13:17 - 07 Apr 2014    Post subject: Reply with quote
It's firing the starter motor solenoid even when the ignition is off? And constantly?
First things first I would disconnect the battery, then starter and check all connections - is anything looking like it's been bypassed or messed with?
What's the history of the bike? Has anyone had a go at the ignition barrel? Has it got all the original keys?
PostPosted: 13:22 - 07 Apr 2014    Post subject: Reply with quote
Jaaayzus, you really did put your head in the noose there. That's the "immaculate" one, right, with no V5C or VED?
It's an electrical short. It could just be the wet shorting the relay, or a stuck starter switch, but I'm going to go with: hotwired.
If you put your location in your profile, someone may take pity and go and have a look, if for no better reason than to see if the VIN has been filed off.
arry
PostPosted: 13:26 - 07 Apr 2014    Post subject: Reply with quote
That's where I was going too - what's the story with the V5 then?
Az
PostPosted: 13:39 - 07 Apr 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=287793&postdays=0&postorder=asc&start=0
zeano182
PostPosted: 13:40 - 07 Apr 2014    Post subject: Reply with quote
The thing is though. Its only had this problem start yesterday. So after doing 200 miles why would it be a hotwiring thing? Im in wakefield.....where woukd the vin number be plz?
arry
PostPosted: 13:41 - 07 Apr 2014    Post subject: Reply with quote
az- wrote:
< Insert 'one born every minute' hilarious meme here >
zeano182
PostPosted: 13:42 - 07 Apr 2014    Post subject: Reply with quote
Just so you all know I ha e learnt my lesson with tjis bike and I have aent off the v62 and spoke to the dvla. But I come here to read and try and help resol e any problems I have a s a new biker......hopefully the piss takibg will stop soon! Haha
SQL
Wakefield?? Jivebunny is good with electrics he could help Laughing
Spray up the switchgear with WD40
PostPosted: 13:44 - 07 Apr 2014    Post subject: Reply with quote
Wakefield, that is totally stolen.
Should be on the headstock really.
zeano182
PostPosted: 13:46 - 07 Apr 2014    Post subject: Reply with quote
The guy is still in contact with me and just been and had a look and the vin is there.
PostPosted: 13:48 - 07 Apr 2014    Post subject: Reply with quote
But is it yours...
Have you done a full HPI check?
You've bought a bike, with no real V5 so you can't check the VIN is correct.
zeano182
PostPosted: 13:49 - 07 Apr 2014    Post subject: Reply with quote
Ysa hpi check came back tottally clean.......remarkably.
zeano182
PostPosted: 13:55 - 07 Apr 2014    Post subject: Reply with quote
Ysa hpi check came back tottally clean.......remarkably. also just dobe a vin check on the hdi check and it says it matches correctly
zeano182
PostPosted: 13:56 - 07 Apr 2014    Post subject: Reply with quote
PostPosted: 14:03 - 07 Apr 2014    Post subject: Reply with quote
Against the plate though, not the VIN.
Eh, don't mind us, we feed on suffering. Drooling
This is really simple stuff. Electricity is getting to the starter when it shouldn't. A multimeter and 5 minutes should diagnose it, or just douse the switchgear and wiring with WD-40. Heck, it's likely fine now that it's dried out.
Hotwired though.
arry
PostPosted: 13:23 - 10 Apr 2014    Post subject: Reply with quote
Sorted?
PostPosted: 14:10 - 10 Apr 2014    Post subject: Reply with quote
Porridge?
mikesaa309
PostPosted: 19:09 - 10 Apr 2014    Post subject: Reply with quote
I once had a similar issue with my CBF. I was riding home from college and everytime I pulled the clutch in I heard this electrical whining noise like a motor. I assumed the worse and thought "great something is up with the clutch". Continued to ride home non the less. Got home and then realized that the starter button had got jammed in. Rolling Eyes
The last post was made 12 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 99.53 Kb
