Engine cutting out at idle
kawasakizxr
PostPosted: 21:32 - 01 Apr 2014    Post subject: Engine cutting out at idle Reply with quote
Hi the past 2 times i have rode the bike it has been cutting out at me at junctions etc.
Bike is a kawasaki zxr 400
If the bike cuts out in gear i have to go into neutral switch off and on the ignition and it starts but just dies again the next time i stop.
This has started since changing the oil, oil filter, coolant, fuel filter and airfilter.
I have tried increasing the idle slightly however its still cutting out just not as often
once above idle the engine is fine.
I understand it could be many things so if you could give me a few things to check that would be great.
Also my chain seems to have a mind of its own. I am having to adjust it evrey time i ride the bike. One minute its tight then next loose. It never stays oiled, looks dry after one ride and iv just noticed some of the links have gone stiff/stuck. Thanks Very Happy
Flatbadger
PostPosted: 21:52 - 01 Apr 2014    Post subject: Reply with quote
I had similar lately, a new battery was required in my case.
You're in ISIS
clancy
PostPosted: 22:02 - 01 Apr 2014    Post subject: Reply with quote
When it's ticking over is it lumpy ? Might need to go higher on the idle, what's it idling at once warm ?
Chain probably needs replacing then, check the sprocket for excessive ware too. Also check your rear wheel when it's elevated, check there's no movement
KLX 300r
kawasakizxr
PostPosted: 22:08 - 01 Apr 2014    Post subject: Reply with quote
it idles between 1200-1500rpm when warm but sometimes drops to 1000rpm and sounds a bit rough.
clancy
PostPosted: 22:35 - 01 Apr 2014    Post subject: Reply with quote
Had a similar problem on my rvf a few years ago, kept upping the idle which helped but eventually needed to replace the plugs and reset the carbs
Might be worth balancing the carbs or getting it done if you can't do it yourself. Also worth checking the plugs for anything out of the ordinary
KLX 300r
kawasakizxr
PostPosted: 07:44 - 02 Apr 2014    Post subject: Reply with quote
Hi the plugs were changed last year and i have done very little miles since. I last balanced the carbs last year it was running fine so was going to leave it but it seems i may have to do this again.
clancy
PostPosted: 11:09 - 02 Apr 2014    Post subject: Reply with quote
It's worth checking of its not too much trouble , there's nothing in particular that put mine off when it happened
If its unbalanced the plugs might be fouled, just pop one out and have a look at it
KLX 300r
Motorhate
PostPosted: 14:16 - 02 Apr 2014    Post subject: Reply with quote
My FZ was doing exactly the same thing. I had one inlet rubber that was completely knackered so that will need to be replaced. Also the carbs could probably do with a clean too.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
kawasakizxr
PostPosted: 15:19 - 08 Apr 2014    Post subject: Reply with quote
Hi balance on the carbs is fine have checked it today.
I tried running the bike at idle until warm. Then switched the headlights on and had the indicators on (as though i was sat in traffic) as soon as i blip the throttle or the cooling fan kicks in the engine cuts out.
Sounds like a electrical fault battery alternator etc ?
Copycat73
PostPosted: 15:26 - 08 Apr 2014    Post subject: Reply with quote
time for a multi meter voltage test.
caveat emptor
The last post was made 12 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 67.73 Kb
