Liquid Coming from Exhaust
HotdogMcDraw
PostPosted: 15:52 - 08 Apr 2014    Post subject: Liquid Coming from Exhaust Reply with quote
Hi,
Took my 125 out today, first time in a few months and noticed a watery substance at the end of my exhaust. I gave it a wipe and looked dirty and a little rustic, could it be just water stuck in my exhaust after being in storage for a few months? It doesn't smell like petrol or oil so hopefully it is not anything too serious.
It's air cooled by the way so coolant is out of the question. Hopefully it's not piston rings or anything like that as it is riding as it should be with no suspicious noises etc, but if anyone has had a similar experience or knows why let me know.
Much appreciated.
map
Mr Calendar
PostPosted: 16:00 - 08 Apr 2014    Post subject: Reply with quote
My bet too would be water/condensation.
Best go for a long, quickish run, making sure everything up to temperature.
Then look at it again.
HotdogMcDraw
PostPosted: 16:19 - 08 Apr 2014    Post subject: Reply with quote
Wow quick reply Smile
Thanks guys, will take it for a long burn tonight and see how it goes from there.
Cheers.
Llama-Farmer
PostPosted: 17:05 - 08 Apr 2014    Post subject: Reply with quote
Almost certainly just water.
You can get it even if the bike hasn't been sat for months... my car does it on a daily basis unless its warmer than about 20 degrees air temp.
My bike doesn't seem to do it but perhaps because the silencer and exit is much higher up than the rest of the systems and condensation will drain to the lowest point, whereas on the car the system is pretty much level
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
weasley
PostPosted: 17:30 - 08 Apr 2014    Post subject: Reply with quote
When you burn a hydrocarbon you get three things in abundance: carbon dioxide, water and heat (plus a load of stuff in smaller quantities). When you burn a litre of fuel you get around a litre of water vapour created. When the exhaust is cold it acts like a huge condenser and cools the exhaust gases down enough for the water vapour to condense to liquid water. That's why you see plumes of steam from a cold engine on a cold day and it's why water can collect in the exhaust. Once the exhaust has warmed up the water no longer condenses and exits as a gas (which you can't see); any pooled or collected water will also boil away.
HotdogMcDraw
PostPosted: 17:51 - 08 Apr 2014    Post subject: Reply with quote
Nice explanation, put's me more at ease Smile
Llama-Farmer
PostPosted: 18:31 - 08 Apr 2014    Post subject: Reply with quote
The car's probably got a cat on it Thumbs Up
If by cat you mean a catalytic converter, then no it doesn't Rolling Eyes
However if you mean an actual cat, it is quite possible a feline crawled up the exhaust and is now pissing in it
HotdogMcDraw
PostPosted: 21:02 - 08 Apr 2014    Post subject: Reply with quote
Vincent wrote:
Now you know your exhaust could be rotting away from the inside you mean? Smile
Could be Smile, but i just got back and all is good. There was a very small amount of water but it looks like it's sorted, just nice to be on the road... look forward to tomorrow Smile
As long as the exhaust looks good on the outside.... who cares Smile
The last post was made 12 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 74.35 Kb
