Running a ZZR with its fairings off?
Wonko The Sane
PostPosted: 17:47 - 08 Apr 2014    Post subject: Running a ZZR with its fairings off? Reply with quote
I've got an oil leak, I've not taken farings off before but thinking taking the belly pan off and cleaning it and having a look will let me see what the issue is.
I'm not going to have time to do all this at once, would there be any issues taking the belly pan off and using the bike for motorway commuting for a few days before putting it back on?
PostPosted: 18:02 - 08 Apr 2014    Post subject: Reply with quote
Should be fine but at high speed (like near the top speed fo the bike, into three figures) my GPZ 500 used to get quite a nasty little speed weave if you left the belly pan off.
Wonko The Sane
PostPosted: 18:40 - 08 Apr 2014    Post subject: Reply with quote
I don't get opportunities to do that on a busy motorway but thanks for the heads up
CaNsA
PostPosted: 18:43 - 08 Apr 2014    Post subject: Reply with quote
You might get pulled by the rozzers as I think the bike might not be "fit for road use" with pipes n sharp bits exposed.
When turning a faired bike into a naked you have to make sure that all that stuff is hidden away.
I might be wrong, it has happened in the past.
PostPosted: 19:01 - 08 Apr 2014    Post subject: Reply with quote
Rode my Blackbird with no mirrors, no fairing lowers and a cracked screen and upper nose cone for about a week diagnosing charging faults and oil leaks.
Didn't get pulled at all, fairly good going. Wind on motorways is definitely noticeable but probably won't affect you Thumbs Up
Wonko The Sane
PostPosted: 19:03 - 08 Apr 2014    Post subject: Reply with quote
wind catching the bike in an odd way I'm a bit worried about as some of my commute is very exposed / gusty
one part is over the manchester ship canal on a high motorway bridge, the other the motorway weaves up a valley and wind batters around it at random.
Hadn't thought of the potential sharp items exposed, guess it's judging if it's ok once the belly pan is off.
Pete.
PostPosted: 19:33 - 08 Apr 2014    Post subject: Reply with quote
Unless there's an actual sharp projection like a pointy fairing bracket they won't bother you. Bikes have footpegs and levers sticking out after all.
a.k.a 'Geri'
johnsmith222
PostPosted: 19:45 - 08 Apr 2014    Post subject: Reply with quote
ridden my ZZR for around 6 months with the belly pan off because I've been too lazy to put it back on (it takes like 2 minutes). Not been pulled over and hadn't even considered it a possibility tbh.
GrumpyGuts
PostPosted: 01:16 - 09 Apr 2014    Post subject: Reply with quote
For the oil leak, I would check if it is coming from the spark plug drain o-ring. After buying my ZZR, I discovered it was pissing oil out all over my right boot.
In the end I gave up and the Kawasaki mechanic discovered that one of the o-rings was damaged and allowing oil to seep through.
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Clarkie
PostPosted: 17:30 - 09 Apr 2014    Post subject: Reply with quote
Just repaired an oil leak on my old man's ZZR, was coming fromt he water pump which is apparently a common fault on them, hope that helps.
Wonko The Sane
PostPosted: 18:36 - 10 Apr 2014    Post subject: Reply with quote
Just tried to take the crash bungs off to then take the fairing off but the bolt (tis the engine bolt) just spins and isn't having any of it and I can't see how to get a spanner in behind to hold the nut.
garage will have to do it.
Motorhate
PostPosted: 19:23 - 10 Apr 2014    Post subject: Reply with quote
My FZ750 has had the fairings off for years and was even ridden with no mirrors at all so I wouldn't worry about it. It's gone from something like this ...
https://www.motorbikespecs.net/images/Yamaha/FZ_750__Genesis_89-91/FZ_750__Genesis_89-91_1.jpg
to this ...
https://i61.tinypic.com/2dsfhgn.jpg
Be prepared to be windswept on a motorway at full speed though.
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
The last post was made 12 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 73.19 Kb
