| unluckyluke |
 unluckyluke Nova Slayer
| gsmunn |
 gsmunn Nova Slayer
| 1198 |
 1198 World Chat Champion
| unluckyluke |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 19:12 - 09 Apr 2014 Post subject: |
Used wurth chain wax for a while which is translucent, although if it does flick dirt is obviously going to stick fairly quick anyway. Fairly flick proof though - but does need the chain to be thoroughly warm after a ride to get it into the chain nicely, and ideally a quick run straight after to help it settle too - so in terms of time and difficulty its not much better than standard oil/lube overall.
I've reverted to general chain lubes recently for the above reasons. Any of the standard ones are fine, generally used Motul/Wurth/Muc off - just whatevers cheapest and handy at the local shop. Plenty of people use old motor oil too, may well be good enough.
For cleaning a toothbrush is good enough, but I find one of these handy personally
https://tinylink.net/p19pl
Cut up old tshirts make good rags too  |
| 1198 |
| unluckyluke |
 Posted: 19:22 - 09 Apr 2014 Post subject: |
Thanks for your help people, never realised you could get a wax type product. Will give that motul stuff a try and it looks dead easy with the built in brush. The less I have to clean off the rear wheel of my zx6r the better, the powder coating on the wheels is dreadful and scrubbing it not only gets the oil off but bits of paint too  |
| -Matt- |
 Posted: 19:30 - 09 Apr 2014 Post subject: |
You shouldn't need to scrub it much at all. The sides of my powdercoated wheels are flaking where they got damaged replacing tyres but they've remained like that without further flaking for a couple of years now.
I'm sure theres plenty of other products or even bog standard spirits that would do the same job perhaps, but i've used this on the wheels for ages and it gets them spotless with a couple of light wipes of a cloth with some splashed on. Bottles lasted me almost 3 years of occasional wheel cleaning so far
https://tinyurl.com/nhmmvgp
You can pick it up in your local Halfrauds probably, usually have them in stock. In all honesty though if you have light coloured wheels, its a losing battle, dust will accumulate on them quickly whether you get chain flick or not. I gave up on cleaning my gold wheels most of the time as its just hopeless  |
| delsol |
 delsol World Chat Champion
| Dave500 |
 Dave500 Traffic Copper
 Posted: 19:41 - 09 Apr 2014 Post subject: |
Use WD40 degreaser (or any WD40) on your back wheel mate, a couple of coats and get a detailing brush(they are nice and soft) and its a peice of piss  ____________________ Bye bye Z hello Versys  |
| Enduro Numpty |
 Enduro Numpty Could Be A Chat Bot
 Posted: 20:31 - 09 Apr 2014 Post subject: |
Chain lube is specifically designed to attach to everything apart from motorcycle chains. That's why there are so many cleaning products on the market. Same reason as offroad motorcycle air filters are coated with the stickiest oil known to mankind - so all us suckers buy more chemicals clean it all off.  |
| Boris the spider |
 Boris the spider Nearly there...
 Posted: 21:42 - 09 Apr 2014 Post subject: |
Well after years of trying various anti fling chain lubes.
I finally started using 80/90 gear oil.
£9 a litre. Use it on both bikes.
Brilliant stuff.
Why did I wait so long and waste a fortune on expensive chain lubes  ____________________ Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself. |
| c-m |
 c-m World Chat Champion
| Dave70 |
 Dave70 World Chat Champion
| clancy |
 clancy World Chat Champion
| Boris the spider |
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 07:15 - 10 Apr 2014 Post subject: |
After messing about with various chain lubes for a while, I finally broke down and got a chain oiler (Tutoro Auto) and haven't looked back. The Tutoro one doesn't cost the earth and doesn't need to be hooked up to any electrics, but still works well enough. The electric ones are probably better, but I could install this one myself with my non-existent mechanical skills.
An oiler also seems to keep the chain cleaner for longer. I wipe it down with a rag once a blue moon, and that's on a bike that does 1,000 miles or so a month.
Prior to that, on my 125 and when I first got the NC700, I used Wurth or a brand called Rock Oil. The latter flung less, but all of them fling to some extent. It's part of how they work. I cleaned the chain every other week too. My chains were spotless, but didn't last much longer than the rusty chain on my neighbour's bike. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| Richy CB1000 |
 Richy CB1000 Trackday Trickster
| LaurenceR46 |
 LaurenceR46 Renault 5 Driver
| Davie J |
 Davie J Scooby Slapper
| -Matt- |
 Posted: 14:10 - 10 Apr 2014 Post subject: |
Wouldn't mind trying this, how are you applying it normally just pouring into a cloth and wiping or putting it in a sprayer? |
| clancy |
| unluckyluke |
 Posted: 18:03 - 10 Apr 2014 Post subject: |
Hadn't thought of chain saw oil! I work in a tool hire shop so have access to plenty of the Stihl stuff. Will give that a try as well. |
| Davie J |
| -Matt- |
 Posted: 13:51 - 11 Apr 2014 Post subject: |
Cheers, definately will give the brush/chainsaw method a go
Presume its quite easy to see when it gets dry too, thats one of the things that really annoyed me with the wax you'd have to rub your hand all over it to check  |
The last post was made 12 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
