Speedfight 2 jetting
Jackward
PostPosted: 17:48 - 11 Apr 2014    Post subject: Speedfight 2 jetting Reply with quote
Hi everyone. Ive got a 2001 peugeot speedfight 2 liquid cooled derestriced with 8 gram rollers. I was running a technigas with a 72 jet in and the spark plug was a blacky brown colour. My exhaust broke so i fitted a stage 6 pro replica and it needs jetting up this is were i am having trouble this is what ive done so far
Picture 1- This is a new spark plug with and 85 jet after a 5-6mile ride then turned off at full throttle. The bike didnt bog when i let off the throttle then went back onto it. but going down hill at about 48 if i let off and go on it will bog. ive had an 82 jet in and an 88 but i didnt use new plugs and couldnt tell any difference.
Picture 2- is with the 88 jet in. I no this would be too rich and i didnt use a new spark plug but i couldnt tell the difference between the 85 and 88 jet.
Picture 3- this is with the 85 jet without a new plug
Do you think i need to go up from and 85 jet or down? im not sure what to do thanks for any help in advance
gavcarter
PostPosted: 18:01 - 11 Apr 2014    Post subject: Re: Speedfight 2 jetting Reply with quote
Probably because your going down hill....
how is it too rich if you cant tell the difference?
You need a new plug ( or at least to give it a good clean) to do this properly - and you don't need to go on a 5-6 mile ride you can do it on centre stand with back brake on very slightly just to give the engine a small load. Plug wants to look like you just have blown extremely fine chocolate powder on it
Jackward
PostPosted: 18:06 - 11 Apr 2014    Post subject: Reply with quote
How long would you recommend i do it for mate?
Nobby the Bastard
Harley Gaydar
PostPosted: 18:07 - 11 Apr 2014    Post subject: Reply with quote
Until it goes bang. Then you have an excuse to buy a proper bike.
Triumph Sprint ST 1050
Jackward
PostPosted: 18:09 - 11 Apr 2014    Post subject: Reply with quote
thanks Mr helpfull Thumbs Up . If i could afford one i would. My familys no got alot of money and im full time at college and there not much workin going on at the moment were i work
gavcarter
PostPosted: 18:17 - 11 Apr 2014    Post subject: Reply with quote
a minute should be more than enough to get a colour on the plug
Nobby the Bastard
Harley Gaydar
PostPosted: 19:56 - 11 Apr 2014    Post subject: Reply with quote
To be frank, if you are tyring to tune a modified 2 stroke without a dyno you should be happy that the fucker even works, let alone trying to optimise it.
gavcarter
PostPosted: 20:03 - 11 Apr 2014    Post subject: Reply with quote
bit of this
https://www.bmridersclub.com/images/Holed%20Piston.jpg
bit of that
https://farm6.static.flickr.com/5013/5502827159_361b9a0b44_m.jpg
few of those
https://met-tech.com/images/clip_image002_048.jpg
then he will know how far to go next time Wink
evoboy
PostPosted: 01:02 - 12 Apr 2014    Post subject: Reply with quote
If its a 50cc speedfight, your rollers are far too heavy so it will never rev enough for you to jet it correctly.
Less than 6gram is normally a good starting point.
APT Motorcycles
Jackward
PostPosted: 11:19 - 12 Apr 2014    Post subject: Reply with quote
Thanks both. As it happens i do have some brand new 6 gram rollers had them in with the technigas but that didnt work well. Ill get them in asap and see how it goes
evoboy
PostPosted: 21:47 - 12 Apr 2014    Post subject: Reply with quote
The stage 6 pipes tend to be quite 'high revving' so the lighter rollers will help get the engine revving in the best range for that pipe.
It also depends how heavy you are as to what roller weight you choose.
If the plug is coming out on the blacker side of tan coloured, then i would sort out the gearbox tune before going much further with the jetting.
APT Motorcycles
Jackward
PostPosted: 22:40 - 12 Apr 2014    Post subject: Reply with quote
Cheers. Ive got some 5.5gram and i weigh about 12 stone. They will be going in tomorrow and i will post a pic and info on when done
Jackward
PostPosted: 22:41 - 12 Apr 2014    Post subject: Reply with quote
Jackward
PostPosted: 15:19 - 13 Apr 2014    Post subject: Reply with quote
Put 5.5s in and i just revs really high and seems to be unable to go past 20mph
gavcarter
PostPosted: 15:25 - 13 Apr 2014    Post subject: Reply with quote
Has the variator spring been changed for a stiffer one?, might be worth giving the variator and clutch a quick service just to make sure it all moves freely and none of the pulleys are binding on the shaft
Jackward
PostPosted: 15:46 - 13 Apr 2014    Post subject: Reply with quote
Ive never changed the spring and my friend who had it before has never changed it. All the variator and clutch have been off and cleaned a couple of days ago. Its just wierd how i put 8grams in and it will do 55 but less that 7 and it will struggle but all my mates are running about the same speeds but they all have 5gram and under rollers? Cheers
Also a wierd thing is its had the same clutch atleast 2 years and the pads still look like there brand new?
UPDATE clutch pictures
+ variator slides look worn? also snapped one Sad
Clutch pads are smooth and shiny? sure this a bad thing
Jackward
PostPosted: 17:50 - 13 Apr 2014    Post subject: Reply with quote
Things are starting to go normal now. Got another standard variator with a malossi back plate put the 5.5s in no luck still. But put 7.5s in and huge difference straight away big difference in pulling power could even feel it pulling up past 35mph but after it got to operating temperature it seemed to drop back to like it was with 8s but the bike is running rich at the moment. Im thinking i need to try some 7grams what you think?
85 jets definetly too big as it was running a 72 jet with my technigas and theres excess oil coming out my can onto the exhaust so a 13 jet size increase is abit stupid. So im feeling that it will be safe running the 82 jet without risk of damaging the bike?
on the phone i was told it would be around 80 but start at 85 to be safe as they have not finished dynoing the exhasut so they dont know what size it could be. Also seen someone who has a leo vince zx hes running an 82 jet and these exhausts are roughly the same
evoboy
PostPosted: 19:15 - 13 Apr 2014    Post subject: Reply with quote
The contrast spring in the rear pulley is too stiff. It will of been changed to a stiffer one. You need the heavier weights to overcome the stiffness of the spring. All that does is put excess stress on the engine, rollers and belt.
If your running just a stock 50cc kit with a pipe then the standard weight spring will be fine.
Youll then find it will rev about the same as it does now, but most likely be quicker in acceleration and top speed.
With the jetting, just keep going up in jet size 1 size at a time till the engine bogs at full throttle, then go smaller by 1 size.
APT Motorcycles
Jackward
PostPosted: 20:33 - 13 Apr 2014    Post subject: Reply with quote
Cheers i think you could be right. My springs black and the only black one i can find is 1500rpm so im guessing 1000rpm is a standard spring?
Orderd some 6.5 rollers and i can mix.them with my 7.5s to make 7 gram too. If it runs bad with the 6.5s ill know for sure its the torque.spring
The last post was made 12 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 112.39 Kb
