Homemade battery cut off switch
Adam80UK
PostPosted: 08:16 - 12 Apr 2014    Post subject: Homemade battery cut off switch Reply with quote
To save my battery over longer periods of inactivity, I'm considering a isolating switch for the battery.
Ideal run from the battery to under the seat cowl.
Can anyone give advice on what wire I should use, and any specifics on what the switch needs to be?
I know you can buy ones with big red key etc, but I just want something smaller really and not for security issues.
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
drzsta
PostPosted: 08:28 - 12 Apr 2014    Post subject: Reply with quote
How about put it on a trickle charge then?
Adam80UK
PostPosted: 08:34 - 12 Apr 2014    Post subject: Reply with quote
Sadly garage is in a block so no power and as I go through periods of frequent use sometimes I don't wish to remove and fit the battery each time.
c-m
PostPosted: 09:02 - 12 Apr 2014    Post subject: Reply with quote
Of course the OP could take the battery out and charge it that way. Perhaps that is what you mean?
It bug me that people on here assume that everyone with a motorcycle has a garage or even a driveway and access to power? It's not that common. Most houses in towns and cities do not have powered garages, plus you've got people living in flats and other accommodation.
In terms of adding a battery cut off, I wouldn't bother. The battery is going to discharge on it's own anyway. I bike even with an alarm draws hardly anything.
anthony_r6
PostPosted: 09:14 - 12 Apr 2014    Post subject: Reply with quote
As above, you're gonna get the batter losing power over time anyway. Put it in your house and trickle charge it. Then pop it back in when you want to use it. Best way to maintain it. How hard can it be to pop your battery back in? It's not like you have to take it out after every ride, just when you know you're not going to use it for a few weeks.
Adam80UK
PostPosted: 14:23 - 12 Apr 2014    Post subject: Reply with quote
The thing is, I don't know when I'm not going to be using it for a few weeks really.
Bike has an alarm but even in the mode which draws least power, it still draws some. That's why I want a switch really.
Adam80UK
PostPosted: 14:24 - 12 Apr 2014    Post subject: Reply with quote
Adam80UK
PostPosted: 16:06 - 12 Apr 2014    Post subject: Reply with quote
Rather than a switch for the battery, how about a switch for the alarm, if that's what is causing the drain? Keep it small and discrete, somewhere under something lockable so it doesn't defeat the purpose of having an alarm. Wire gauge will only need to be that of the alarm's.
If you want to go fancy, have something like this :-
https://www.maplin.co.uk/p/05a-spst-miniature-short-round-type-cj92a
Islander
PostPosted: 16:10 - 12 Apr 2014    Post subject: Reply with quote
To switch the feed off to your alarm will cause problems. It will probably set the alarm off (they're designed to detect the battery being disconnected) unless you put it into maintenance mode which, if it's like mine, will cause it to beep periodically as a reminder that it's in that mode.
PostPosted: 16:14 - 12 Apr 2014    Post subject: Reply with quote
Which it would do if the battery was on a switch and disconnected anyway.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:37 - 12 Apr 2014    Post subject: Reply with quote
Why not just disconnect the fucking battery? It's not hard to remove one connection
Triumph Sprint ST 1050
Islander
PostPosted: 16:49 - 12 Apr 2014    Post subject: Reply with quote
Yes that's my point. Switch off the battery or switch off the feed to the alarm and it'll go off - it'll have an internal battery to power the sounder. Put it in maintenance mode and it'll beep at a set interval. Either way it'll cause problems.
Islander
PostPosted: 16:51 - 12 Apr 2014    Post subject: Reply with quote
Because it will set the alarm off.
_mjs_
PostPosted: 17:10 - 12 Apr 2014    Post subject: Reply with quote
Bump that shit.
smegballs
PostPosted: 17:57 - 12 Apr 2014    Post subject: Reply with quote
I put on one my GS back along. As long as the switch is rated greater than the main fuse all should be well. I just had a 30A one tucked away under the sidepanel. Something else to confuse a would-be stealer.
MY CB doesn't have an ignition switch, just has a hidden battery isolator.
BTTD
PostPosted: 22:00 - 12 Apr 2014    Post subject: Reply with quote
Yeah, unless you have to remove the tank to get to it, or even better unbolt a load of shit and then remove the bikes ecu. Not all bikes have easy access to the battery - some are a right ball ache.
I fitted a cut off to a bike using a short length of high capacity welding cable (nice and flexible) and one of those isolation switches.
https://www.beal.org.uk/automotive/switches/flasher-units/battery-isolator-switch-100a/prod_1929.html
In summary, it wasn't ideal as it's all a bit bulky - you want to keep the cable as short as you can while making the cut off as accessible as you can.
Alternatively, could you use a solar panel with a voltage regulator (so you don't risk frying the battery)?
https://www.ebay.co.uk/itm/Solar-Charge-Controller-Solar-Panel-Battery-Regulator-12V-24V-UK-Stock-/201071364377
The last post was made 11 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 96.2 Kb
