Gearbox Oil
simon1221
PostPosted: 17:59 - 06 Jan 2005    Post subject: Gearbox Oil Reply with quote
hi
i went to my local car spare shop to try and find a bottle of gearbox oil for my bike the guy said they dont do that type anymore, it was replaced with another one, but it is slightly different?
i really dont understand the system of 10w, 20w etc
can i not just put a closer one in:?
haynes manual: 10W 30SE
closest in shop: 5W 20SE
PostPosted: 18:56 - 06 Jan 2005    Post subject: Reply with quote
The numbers are to do with the viscosity range of the oil over its designed operating temperatures. The higher the number, the thicker the oil.
I think the w referrs to it being suitable for use in winter but am not certain on that point.
The SE referrs to the resistance of the oil to damage due to shear stress, the further up the alphabet the letter after the S is, the more shear resistant (and therefore better). SE is old oil with a low shear resistance, I would seriously doubt if there is oil for sale today at less than SG rating, so anything you put in should be ok from that point of view.
So the 5w-20 oil is basically thinner than the stuff your manual recommends although broadly the same in the main part of its working temperature.
Given it is an older bike I would probably go for a 10w-40 oil in the gearbox. This is now pretty much the standard motorcycle oil and in an older gearbox I would probably err on the side of slightly thicker oil, it will make the gearshift appear a bit smoother if there is any wear in there.
simon1221
PostPosted: 19:02 - 06 Jan 2005    Post subject: Reply with quote
thanks, i will get some tomorrow
PostPosted: 19:39 - 06 Jan 2005    Post subject: Reply with quote
The S in SE stands for "Spark" as it is oils for petrol engines rather than compression ignition engines (diesels). SE is quite an old oil spec, but most bikes are not designed to need the latest greatest oil.
A 10W30 is an oil that acts as a 30 weight oil when hot and a 10 weight oil when cold (in Winter).
Personally I would say that the 30 bit is the most important bit on a 4 stroke, but on a 2 stroke gearbox I am not so sure. Would probably go for a 5W30 but failing that a 10W40.
ZRX61
Victor Meldrew
PostPosted: 18:01 - 09 Jan 2005    Post subject: Re: Gearbox Oil Reply with quote
simon1221 wrote:
hi
Find another shop staffed by people who have a clue.......
kasandrich
PostPosted: 20:45 - 09 Jan 2005    Post subject: Reply with quote
I agree with Kieths posting here, but would add that oild sold specifically for bikes are expensive.
I have been using an own brand 10w40 semi-synthetic from Motaquip, motor-factors, in our cars for some time, my local trusted bike workshop had exactly the same can on the side when i went in, so I talked to him about it, he said yes its fine in bikes. This costs just £10 inc vat, for 5 litres. whereas similar spec, bike oil costs £25.
The only thing you have to be aware of is that because a bike has a wet clutch, some car oils, claim to reduce fuel consumption and such like, this is done with friction reducing additives, which can make a wet clutch slip.
Richard
CBR1000FM
simon1221
PostPosted: 23:29 - 09 Jan 2005    Post subject: Reply with quote
i got the 5W30,
runs fine, very smooth and quiet compare to old (very old, grey coloured with bubbles in Thumbs Down ), it is semi-synthetic, i have not yet noticed any clutch slip
thanks for your help
Bomberman
PostPosted: 11:56 - 11 Jan 2005    Post subject: Re: Gearbox Oil Reply with quote
That's bollocks mate. Go to a bike shop (as oppose to Halfrauds et. al.) and they should have it. Having said that, I know of only one place in Sheffield that still sells it Shocked
simon1221
PostPosted: 21:37 - 14 Jan 2005    Post subject: Reply with quote
it runs fine now, im not sure but i think the clutch did slip right after it was changed, but hasnt done it since (another 50miles), so thats great Thumbs Up Razz
i only went because my usual bike shop got moved into another industrial estate and i couldnt find it cos they wanted to biuld anuther supermarket Sad I still havent found it yet Confused
The last post was made 21 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 63.55 Kb
