i corner wrong...
lihp
PostPosted: 22:11 - 12 Apr 2014    Post subject: Reply with quote
Practice
Sload
PostPosted: 22:27 - 12 Apr 2014    Post subject: Reply with quote
Fix throttle?
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
lihp
PostPosted: 22:31 - 12 Apr 2014    Post subject: Reply with quote
Fix hand that uses the throttle
PostPosted: 22:31 - 12 Apr 2014    Post subject: Re: i corner wrong... Reply with quote
If it's FI, then it's just a case of getting used to it.
If it's carbed, then it's a case of sorting whatever the problem is, because while not-so-good FI can cause those issues, you shouldn't have them with carbs and it should be fixable if you do.
Another option for Lydden may well be to downgear it, so you have more gear ratios.
Sload
PostPosted: 22:33 - 12 Apr 2014    Post subject: Reply with quote
True, my Triumph model was well known to have a very choppy throttle so I tweaked the map to make it more usable. Never fully got it as smooth as a carb bike but it felt far safer during throttle transitions after tweaking.
lihp
PostPosted: 22:58 - 12 Apr 2014    Post subject: Re: i corner wrong... Reply with quote
I think it's not "snatchy" but more responsive than being in a low gear on the road, especially for new track riders.
CaNsA
PostPosted: 22:59 - 12 Apr 2014    Post subject: Reply with quote
Would it be worth feathering the clutch ever so slightly when powering out of the corner while in 2nd gear?
Or would that just be asking for trouble?
PostPosted: 23:12 - 12 Apr 2014    Post subject: Re: i corner wrong... Reply with quote
Fair point, on that; make sure your arms are relaxed. Overly tight grip and rigid arms can make this sort of thing much worse.
CaNsA
PostPosted: 00:51 - 13 Apr 2014    Post subject: Reply with quote
tried that it feels as ive im going to throw the back end out, it dosen't really do gentle, its 1000 rpm or 5000 rpm no real inbetween
Pull the carbs, give them a clean.
The last post was made 12 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Racing & Trackdays All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 68.83 Kb
