KMX 125 mixture + MPG issue
Curtisg890
PostPosted: 17:49 - 13 Apr 2014    Post subject: KMX 125 mixture + MPG issue Reply with quote
I got my 1990 KMX 125 on monday and when riding for the first time it stuttered horribly just before 7K rpm but if i held the throttle half way, it would creep past it and be fine. I cleaned the carb out multiple times with compressed air and carb cleaner but made no difference. I found out it had no air filter so i thought that might have been the problem but putting one on only made the stuttering worse and wouldn't go past 7k at all.
Just out of curiosity i removed the top of the air box and rode it like that, it ran perfectly! so it was running too rich. But now i'm confused as to why it doesn't run properly with the cover on.
Another issue is that i'm only getting 60 miles out of £10 of petrol! i've done alot of research and i should get atleast 90-100. I've checked for leaks and adjusted the float valve but has made no difference.
Any help would be appreciated,
Thanks (:
PostPosted: 17:57 - 13 Apr 2014    Post subject: Reply with quote
Is the main jet standard?
Curtisg890
PostPosted: 18:00 - 13 Apr 2014    Post subject: Reply with quote
Yeah, it's all factory :/
gavcarter
PostPosted: 18:29 - 13 Apr 2014    Post subject: Reply with quote
do a compression test
Curtisg890
PostPosted: 18:37 - 13 Apr 2014    Post subject: Reply with quote
As it is at the moment with the top off the air box, it runs perfectly and accelerates fine, so i doubt it would be a compression issue.
gavcarter
PostPosted: 18:38 - 13 Apr 2014    Post subject: Reply with quote
not a major one but if its a bit down on power, could explain the fuel loss....
Curtisg890
PostPosted: 18:40 - 13 Apr 2014    Post subject: Reply with quote
It's far from down on power Razz. It's more of a fueling issue i think
PostPosted: 19:04 - 13 Apr 2014    Post subject: Reply with quote
Might be worth checking the jets in detail in case someone has modified them (it is possible to buy jet drills to drill out jets to larger sizes.
Also check the float height, although if that was out enough to cause it to run seriously rich I would expect it to flood when parked.
Curtisg890
PostPosted: 19:08 - 13 Apr 2014    Post subject: Reply with quote
Ah, yeah good point! i'll have a look.
Curtisg890
PostPosted: 20:31 - 13 Apr 2014    Post subject: Reply with quote
Right, just went to take the carb off and fuel started to pour out of the pipe between the carb and airbox, so i've adjusted the float valve again so it shuts off earlier but it might need a new one by the looks of it.
The Main jet looks unmodified, by the way
The last post was made 12 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 62.77 Kb
