| mattfender666 |
 mattfender666 Nova Slayer
| ficedula |
 ficedula Scooby Slapper
 Posted: 20:23 - 13 Apr 2014 Post subject: Re: XJ600n reserve switch and tank range |
| mattfender666 wrote: | Hi guys if i fill up and run tillthe bike starts cutting out, then switch to reserve, nothing changes, a light in the tank shows its empty... Both plastic tubes inside the tank are attatched to the tap , could this be a problem with the tap seals/ diaphragm??
If the tank's actually empty, then it sounds like something's up.
Are you sure the tap 'handle' is on the right way around? It shouldn't be possible to put it on backwards - so you think it's pointing one way when it's actually pointing the other - but I suspect it could probably be bodged on incorrectly if you really tried...
| Quote: |
Also, i seem to be using a LOT of fuel, admittedly i dont hang around and i do use ful rpm range, but im using a full tank of fuel on 90 miles!!! |
Doesn't sound right at all. I fill my XJ600n up at ~180-190 miles, and it's not on reserve at that point (although getting close, judging by how much petrol goes in to fill up). I'm not on full throttle constantly, but I'm not going out of my way to ride as efficiently as possible either, so 90 miles is waaaaay off what you should expect. ____________________ Bike history: YBR125 -> XJ600 |
| mattfender666 |
 Posted: 20:56 - 13 Apr 2014 Post subject: |
Hi there thanks for replying the tank is definately empty when i switch to reserve :/ as for the tap being on the wrong way im not sure, as it turns to all 3 positions no problem at all, how would i go about ensuring it is on correctly? As it stands at the moment, down is on, middle is prime and up is reserve??
As for fuel consumption im not sure whats going on :/ i have just fitted a new chain and sprocket kit as the old set were knackered, im having other issues with the bike too which i geuss i will have to resolve first before i can get an accurate mpg reading. Heres to hoping the chain etc will help!!! |
| mattfender666 |
| ficedula |
| mattfender666 |
| ficedula |
| mattfender666 |
| bodger |
 bodger Nova Slayer
| mattfender666 |
 Posted: 20:27 - 14 Apr 2014 Post subject: |
Evening all and a huge huge thanks to everyone for their helpful words of wisdom!!!
I took her out for a good ride today after filling her up and ive managed to ride 70 miles and have used just under a quarter tank of fuel, great success!!! I geuss the old knackered chain and cogs were killing the mpg!!! Thanks for the info on the thrust bearing dudes , i will order one asap, along with a new clutch cover gasket and possibly some new plates and springs!!
Again huge thanks guys  |
The last post was made 12 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
