Engine noise (tapping or knocking) Piaggio Xevo 125cc
newboy
PostPosted: 18:21 - 13 Apr 2014    Post subject: Engine noise (tapping or knocking) Piaggio Xevo 125cc Reply with quote
Hi all
I know it's a hard one, but has anyone else here had or have experience on this noise? Hopefully someone with a good mechanical brain and ear can give us idea. Also the noise seems to go with higher revs.
Please see the link & Thanks for watching.
https://youtu.be/go36m0n2eKc
Thank you
Piaggio Xevo 125 2010
hmmmnz
PostPosted: 00:09 - 14 Apr 2014    Post subject: Reply with quote
jesus that sounds horrible,
weird how the sound disapears when its rev'd
id like to jump on some future band wagon and say big ends, but i kind of don't think its that, may be some thing to do with the variator,
id pull the side cover off and have a look at the rollers and belt etc,
see if you can isolate where the sound is coming from.
if all else fails, a 125 motor from any of the vespa piaggio range should just plop in there, may be even a 200cc motor would fit Very Happy
the humans are dead
I kick arse for the lord
newboy
PostPosted: 00:37 - 14 Apr 2014    Post subject: Reply with quote
Thank you for your time and post, much appreciated.
Thank you
LessIsMore
PostPosted: 12:47 - 14 Apr 2014    Post subject: Reply with quote
Since the knocking happens at low speed, I’d guess it’s coming from worn rollers in the variator. At low speed they’re loose and, being worn, allowed to knock. As speed builds, they’re thrown outwards by centrifugal force against the variator plates, eliminating the knocking.
newboy
PostPosted: 14:39 - 14 Apr 2014    Post subject: Reply with quote
Thanks. LessIsMore. That'd be great if that's the problem, unfortunately I've no money in the pot at the moment to get it looked at, but you've given me a bit of hope...thank you.
Thank you
LessIsMore
PostPosted: 14:47 - 14 Apr 2014    Post subject: Reply with quote
If it’s the rollers (and I’m reasonably confident it is, but when where they last serviced?), you won’t do much harm by continuing to ride the scooter until you can afford to get it looked at.
newboy
PostPosted: 17:35 - 14 Apr 2014    Post subject: Reply with quote
Hi LessIsMore.
I just looked at the last service (Sept 2013) It had listed:
Belt and rollers need replacing?
Valves need adjustment?
Steering head bearings need adjustment?
That's 650 miles since then.
I suppose the question marks mean soon'ish?
I suppose one way to find out would be to take the belt and variator off then run the engine. If there was no noise the I'd know the big end was alright; is that possible or a no no?
Thank you
hmmmnz
PostPosted: 18:44 - 14 Apr 2014    Post subject: Reply with quote
take that side cover off, that will reveal the variator and clutch, along with the belt
like this
https://members.modernvespa.net/fabio_dougie/uploads/image0422a_676.jpg
here a vid of a guy stripping his fuct variator
https://www.youtube.com/watch?v=YdHyZwyHVi4
you'll need a way of stopping the variator from spinning when un-doing the center bolt, either by using a impact wrench, or using a piston stopper (a long bolt that has the same thread as the spark plug that hits the piston and stops it moving)
the humans are dead
newboy
PostPosted: 19:28 - 14 Apr 2014    Post subject: Reply with quote
like this
Hi hmmmnz. Thanks for post and excellent links. I need to get a long shafted extender nut undoer??? to remove my belt case and wrench, then I'll have a go at replacing the belt and rollers. Just one thing, before I go buying the belt and rollers I'd like to check it's not the big end. Would I be able to run the motor whilst the variator is off; If the noise was still there I would know that it's probably the big end then?
Thank you
hmmmnz
PostPosted: 22:21 - 14 Apr 2014    Post subject: Reply with quote
yeah of course you can, its just like revving a normal bike in neutral,
there will be no load on it,
even if the noise is still there it doesnt mean categorically its the big end, it could be the top end, but at that point i'd probably be looking for second hand motors off ebay Very Happy
the humans are dead
newboy
PostPosted: 00:50 - 15 Apr 2014    Post subject: Reply with quote
Mine's the 2010 model (15k miles) which doesn't have the air intake on the transmission case like the earlier models. Would I have to get the same engine; or be wiser to? Couldn't see any 2010 models, unless mines the only one in the world to have blown already LOL!
[/img]
Thank you
hmmmnz
PostPosted: 12:56 - 15 Apr 2014    Post subject: Reply with quote
i think they added the air vent because it would get hot (as seen in the vid above)
nah you should be abe to pop in any of the vespa /piaggio motors,
they tend to use the same motors in a whole generation of bikes,
so any of the 125s for around a 5 year period in any of the models will be the same with minor cosmetic differences,
id be surprised if the motor was gone at that mileage
the humans are dead
newboy
PostPosted: 17:39 - 15 Apr 2014    Post subject: Reply with quote
Thanks hmmmnz. Fingers crossed.
Thank you
newboy
PostPosted: 20:27 - 19 Apr 2014    Post subject: Reply with quote
Well I got the bolts off except the clutch bolt as I never had the sized sprocket. Arghhh!!!
Anyhow please see my updated vid to see if you think it's still rollers v's big end thank you.
https://www.youtube.com/watch?v=zGGu3cSuSmA
Thank you
moonzoomer
PostPosted: 20:33 - 19 Apr 2014    Post subject: Reply with quote
another possible cause could be the starter motor dog gear not disengaging completely from the engine after starting.
newboy
PostPosted: 21:40 - 19 Apr 2014    Post subject: Reply with quote
Thanks moonzoomer.
Never heard that one yet, but I'll take it over big end any day...Pardon the pun... Laughing
Thank you
moonzoomer
PostPosted: 21:45 - 19 Apr 2014    Post subject: Reply with quote
My old honda 125 scooter made the same noise, it was a frayed belt hitting against the transmission cover
newboy
PostPosted: 22:21 - 19 Apr 2014    Post subject: Reply with quote
Thanks to all the helpers I've fixed it now. I took all the parts out, cleaned them and put it all back together. I did notice the the variator nut came off too easily, so that might have been the culprit.
Though I will have to get the clutch and variator nuts off again to superglue them, as I didn't do that in case they had to come off again, Dohhh!!!
I found an absolutely fantastic site for scooters here: https://scootergrisen.dk/scooterhjemmeside/index.php It's foreign but you can use the translate function.
Below is a new edited link to my actions that others may find handy to come across.
"Piaggio Xevo noisy engine or CVT?"
https://www.youtube.com/watch?v=k5Cew6XAQt0
One last thought...Can you use ptfe tape that plumbers use to stop the nuts backing off?
Regards
Paul
Thank you
newboy
PostPosted: 12:55 - 26 Apr 2014    Post subject: Reply with quote
Thank you. I've fixed it..."Hurrah"... Very Happy
Thank you
hmmmnz
PostPosted: 00:57 - 27 Apr 2014    Post subject: Reply with quote
result!! nice one,
use some loctite on the thread to stop that nut loosening off again,
quite satisfying when you fix some thing aye Very Happy
the humans are dead
newboy
PostPosted: 19:44 - 27 Apr 2014    Post subject: Reply with quote
Thanks. I thought it was loctite super glue 'till someone informed me that it was actually loctite 243, which isn't the same thing, so I'll be getting some of that.
I wonder why you can't use 19mm nyloc nuts? (30p)
I was looking variator/clutch nuts on ebay fo £4 each!...Ouch!
Thank you
The last post was made 12 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 116.38 Kb
