brake bleeding
Random13
PostPosted: 11:23 - 15 Apr 2014    Post subject: brake bleeding Reply with quote
Hi All,
I have just rebuilt my calipers and drained the old fluid.
Once put it all back together and time for bleeding , I did feel the servo unit but when I placed the diaphgram back in at the end the level went all the way above maximum and some spilled out .
I think my bikes are ok but can see constant spill from the servo. I think it is due to been overfilled.
Does going above the max limit on brake fluid reduce braking capability because it has no where to pass the air or pressure when the pistons are returned after you let the brake handle go .
I am not sure even if my theory above is correct but certainly the overfill has impacted the brake .
I am going to remove the extra but thought it is worth asking for future reference .
Also do I have to squeeze the diaphgram after it is removed as it seems to have expended in size and is as tall as the low mark . what is its job anyway ? not let water and air in ?
serlant
PostPosted: 11:38 - 15 Apr 2014    Post subject: Reply with quote
what is even going on here? the level of brake fluid in the master cylinder will have zero effect on the brakes? aslong as there is enough then there is enough. there should be a minimum line in the fluid window or on the container, fill it above this. it does not need filling right to the top. bleed the brakes. fill until the sight glass is full (i normally leave the smallest of air bubbles) then put the diaphragm/seal on. then close up master cyclinder.
my guess would be the diaphragm extends so that as the brake fluid level drops as the brake pads wear, a vacuum is not created in the master cylinder, I guess this would result in having to pump the brakes every time you used them.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
davebike
PostPosted: 12:24 - 15 Apr 2014    Post subject: Reply with quote
Servo Unit ?? is the a BMW with the "power Brakes!
AFASK BMW are the only bikes with Servos
If so need to bleed / change the fluid is both the cirkets on whichever brake you are working on the bike has 4 lots of fluid for the brakes
Dave
NC750Xdct + others at work !
[email protected]
Random13
thanks , I know it seemed very confusing .
[quote] a vacuum is not created in the master cylinder, I guess this would result in having to pump the brakes every time you used them.[/quote]
what do u mean by having to pump everytime you use them
PostPosted: 12:39 - 15 Apr 2014    Post subject: Reply with quote
I'm going to assume that you mean master cylinder and not servo.
Over-filling shouldn't have an effect on braking performance. I'm imagine that you've just got air in the system. It can be a sod to get out sometimes. Behind the pistons, lurking in the other pipe of a linked circuit, at the banjos. I'm a recent convert to reverse bleeding by pushing it in at the caliper with a syringe.
It would be helpful if you told us what bike this is.
barrkel
PostPosted: 12:44 - 15 Apr 2014    Post subject: Reply with quote
The master cylinder is a fluid pump. It pumps fluid out of the reservoir into the brake lines. This pushes pistons against the pads, and the pads against the disc, which slows you down.
As the pads wear down, the pistons' "home positions" need to be further out. That means there needs to be more total fluid in the braking system after the master cylinder than with fresh pads. Thus there must be less fluid in the master cylinder. The remaining volume needs to be filled by something. The rubber diaphragm lets the top of the reservoir be filled with air, without needing the brake fluid to be exposed to fresh air.
If this air wasn't there, then there would be a vacuum. If this vacuum was strong enough, it could suck brake fluid from the lines when the master cylinder is in its resting position (there's a small amount of through flow permitted when it's in this state, it lets bubbles escape from the top of the brake lines). If enough fluid was sucked from the lines, it could pull the pistons in from their "home position". This would mean that the brake lever would need to be pumped multiple times to get the pistons extended enough to force the pad against the disc.
Random13
PostPosted: 13:13 - 15 Apr 2014    Post subject: Reply with quote
@barrkel , it makes perfect sense many thank
@Rogerborg, you are right. I meant the reservoir rather than servo . What do you mea by revere bleeding , can you elaborate?
I did try to bleed mine for about 1 hour and all of it was clear fluid so decided to ride it and test it in few days again as maybe some air is up there and not deciding to pup down.
The last post was made 12 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 53.49 Kb
