Rc motors
mic
PostPosted: 20:25 - 16 Apr 2014    Post subject: Rc motors Reply with quote
So. Basically I wanna try build somefink.
To fit inside a 25mm tube....
AA battery holder
Electric motor
Receiver for direction (as in rc controlled)
So with the motor I need it to rotate the propeller 90 degrees so rather than being like a torpedo, the propeller would stick out at a right angle.
Have found small motors and aa holder, not sure what else I need. Any suggestions?!
Thanks
zzr600
The Artist
PostPosted: 05:41 - 17 Apr 2014    Post subject: Reply with quote
Check out RC helicopter spares. You will be able to get Rx boards, a transmitter, servos if you need to control any flaps or anything like that, motors, props etc.
Are you building an RC submarine?
mic
PostPosted: 06:02 - 17 Apr 2014    Post subject: Reply with quote
Not a submarine. However on eBay there's a cheap one for about £8 which should be ok for a donor Laughing
zzr600
The Artist
PostPosted: 06:07 - 17 Apr 2014    Post subject: Reply with quote
What are you building if you don't mind saying?
mic
PostPosted: 06:23 - 17 Apr 2014    Post subject: Reply with quote
Sent a pm about my highly secret classified project
zzr600
Ariel Badger
PostPosted: 06:58 - 17 Apr 2014    Post subject: Reply with quote
Top Secret Project?
mic
PostPosted: 07:07 - 17 Apr 2014    Post subject: Reply with quote
Ariel Badger wrote:
Busted! Although I wasn't thinking pink.
zzr600
PostPosted: 12:38 - 17 Apr 2014    Post subject: Reply with quote
Ariel Badger wrote:
https://www.bondara.co.uk/remote-control-vibrator = Top Secret Project?
MUUUUUM, BANHAMMER. Razz
The Artist
PostPosted: 15:09 - 17 Apr 2014    Post subject: Reply with quote
That explains why the work filter blocked it. Laughing
mudcow007
PostPosted: 10:32 - 24 Apr 2014    Post subject: Reply with quote
i get all my electronics from Hobbyking
you will need at least
RX (receiver)
TX ( transmitter)
ESC (Speed controller - to control the motor)
an as someone else mentioned servos depending on what you want to - if you are getting funky an using loads of servos make sure you get a rx/ tx with enough channels too
The last post was made 12 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 63.59 Kb
