Gilera DNA 49cc - Derestriction
RyanBillingto...
PostPosted: 20:32 - 16 Apr 2014    Post subject: Gilera DNA 49cc - Derestriction Reply with quote
Hello, I was wondering if anyone could offer their thoughts or advice. I'm currently working on my 49cc rev-and-go Gilera DNA. 2005 model.
I bought the bike second hand as stock and I could achieve 32 mph on the flat (as expected) - this would dangerously reduce as soon as I encountered a hill and I started to begin to derestrict the bike accordingly.
Firstly, the rollers were replaced for lighter ones to increase acceleration. The spark plug was changed to an NGK racing sports plug. The relevant washers were removed. The bog standard jet was replaced to a 60 and the needle was altered accordingly for optimum fuel flow. The air filter was replaced with one which allows greater air flow and the exhaust was replaced with a sports exhaust.
Despite all of these changes, the top speed on that flat only increased by 3-4 mph.
I did notice that when I was on the flat, the rev counter only reached 7000 then seemed to stop and hold. After some poking around on the internet I found out that one theory could be that the CDI unit (which is built into the coil block) is restricted to 7000rpm.
Does anybody know how I could derestrict the Gilera DNA 49cc CDI unit? I've heard theories about cutting certain wires/removing washers and tracing back several wires. I don't really want to do any of these without knowing exactly what I'm doing.
Any help/advice would be greatly appreciated.
Thank you,
Ryan.
PostPosted: 20:37 - 16 Apr 2014    Post subject: Reply with quote
Not a CDI restriction on this.
What colour is your spark plug after a big run at max speed?
RyanBillingto...
PostPosted: 20:45 - 16 Apr 2014    Post subject: Spark Plug Reply with quote
The spark plug is a brown colour, slightly damp.
Thank you.
PostPosted: 20:48 - 16 Apr 2014    Post subject: Reply with quote
Whats the top revs you have on there? About 11,000?
RyanBillingto...
PostPosted: 20:53 - 16 Apr 2014    Post subject: Top Revs Reply with quote
It red-lines at 11000, but top revs are 13000. I can reach the red line when the bike's on its main stand and it will rev freely, likewise when it goes down a steep hill. However on the flat, it will not go above 7000.
Thank you.
PostPosted: 20:57 - 16 Apr 2014    Post subject: Reply with quote
What rollers are in there and have you removed the variator restriction?
RyanBillingto...
PostPosted: 21:00 - 16 Apr 2014    Post subject: Reply with quote
The rollers are 6 gram and the variatior restrictor has been removed.
PostPosted: 21:02 - 16 Apr 2014    Post subject: Reply with quote
Reason I ask is you've said you've swapped the rollers to increase acceleration and are expecting top end. You can't really have both, with all the changes you've likely moved where the bike makes peak power. The rollers being wrong can mean you won't get that far in the revs to make use of the new power.
That is as far as I understand it. What pipe is on there?
RyanBillingto...
PostPosted: 21:06 - 16 Apr 2014    Post subject: Pipe Gilera Reply with quote
It came with the standard Gilera exhaust. I took the exhaust restrictor out of it, to allow more gas to escape and I could achieve 35mph.
I then replaced that with a sports exhaust ''Gilera DNA 50cc Technigas Q-Tre Performance Exhaust'' however, this reduced the speed to 26mph???
I've swapped it back and put the standard exhaust on.
This is the source of my information in regards to the CDI restrictor.
https://www.ebay.co.uk/itm/Gilera-Runner-SP-50-since-2006-Ignition-CDI-HT-Coil-Unit-New-/261378224016
Thanks.
PostPosted: 21:10 - 16 Apr 2014    Post subject: Reply with quote
You can't just bolt the new exhaust on and expect win win, you'll have to adjust fueling too and then again on the rollers, swap them out for some other weight ones.
RyanBillingto...
PostPosted: 21:17 - 16 Apr 2014    Post subject: Changes Reply with quote
The rollers and jet were changed to lighter rollers and a bigger jet. It was adjusted and altered bit by bit as changes were made.
My cousins have both had Gileras that could reach over 50mph with the same changes that I've done to this. Adjusting the rollers again would only make a difference of 2/3 mph.
As there is a speed difference of around 20mph between mine and what could be, I was wondering if there was a greater restriction such as the CDI.
This manual states that this model of bike produced after 2004 has a CDI rev limiter.
https://whidbeyislandmoped.com/cart/pub/scooter_tuning_guide.pdf
Thank you for your help,
much appreciated.
PostPosted: 21:22 - 16 Apr 2014    Post subject: Reply with quote
From what I have read, there is no CDI restriction.
Ariel Badger
PostPosted: 21:50 - 16 Apr 2014    Post subject: Reply with quote
I say troll, no pedboi in the history of pedbois has ever managed to write a such a comprehensible and literate posting.
I am glad that I grew up in the age of the FS1E that at 50cc could hit 70 and not all the restricted nonsense.
RyanBillingto...
PostPosted: 21:54 - 16 Apr 2014    Post subject: Troll? Reply with quote
Troll? I'm 17 years old, I don't know much about bikes but what I've learnt I've learnt from my uncle. I'm far from a troll. I've spent all day working on this bike and I can show you pictures of the exhaust and my new exhaust, etc etc. I'm far from a troll, just asking for some advice from bikers who know a lot more than I do.
But if you think I'm trolling, that's fine. Smile
Ariel Badger
PostPosted: 22:16 - 16 Apr 2014    Post subject: Reply with quote
I was pulling your plonker, most of the stuff we get from 17 year olds reads like this..... "Blud I got did ped innit an my M8 sould it mi an he sed it wood go 90 but it onli goin at 40, dose it need a spesul powa band."
PostPosted: 06:29 - 17 Apr 2014    Post subject: Reply with quote
Many moons ago when my daughter had a DNA 50 all I did was remove the variator restrictor/washer and it would run somewhere around the 40mph mark with no other changes.
If I was you I'd put it completely back to standard, without the variator restriction and start from there. 1 thing at a time.
trevor saxe-coburg-gotha
PostPosted: 07:35 - 17 Apr 2014    Post subject: Re: Troll? Reply with quote
RyanBillington wrote:
Troll?
It was actually a compliment - albeit a somewhat backhanded, irony-freighted BCF kind. Wink
Funny too.
GeorgeB.
PostPosted: 09:32 - 17 Apr 2014    Post subject: Reply with quote
My advice - You're 17, not a pedboi... Why are you bothering with a ped then?
Sell it, buy 125, have fun. You could get a shitty CG that'll be quicker than your cousins DNAs, and be safer too Thumbs Up
Current: '99 Fazer 600 | '99 Range Rover P38 4.6 HSE
Previous: Keeway TX125 | CBF 125 | CB400SF Project Big One
CBT 04/12/12 | Theory 03/12/13 | MOD 1 06/01/14 | MOD 2 13/01/14
A100man
PostPosted: 13:33 - 17 Apr 2014    Post subject: Re: Changes Reply with quote
Are you quite sure the cousins aren't pulling your dangly bits ? Have you witnessed their 50 mph peds ? If your bike will rev out to redline on the stand then there can't be a rev limiter so the CDI I guess is OK and it just can't rev under load. What do these machines do in unrestricted countries ? Have you tried dedicated ped forum - eg. mopedarmy ?
Good luck with your quest - we've all been there at one time or another.
Kai.Wilson
PostPosted: 13:44 - 17 Apr 2014    Post subject: Reply with quote
Try 58 jet 2nd from top on the slide and somewhere between 4.5 and 5.5 rollers
My diagnosis is that the speedos are over reading on your cousins bikes. Wink
Andy_Pagin
PostPosted: 14:28 - 17 Apr 2014    Post subject: Reply with quote
I'll do the boring legal bit.
You can't 'de-restrict' a moped, increase its cylinder capacity beyound 49cc or its top speed past 31mph and it ceases to be a moped and becomes a motorcycle.
You have to tell the DVLA that you've changed it to a motorcycle.
You probably need a VOSA one-off type approval to make it road legal.
Obviously you need a provisional motorcycle licence to ride it, you can't ride it on a moped licence.
Tell your insurance company, you're now riding a motorcycle.
Fail to do all the above and get stopped by plod doing 35mph for a few hundred metres and you can (depending on plods competence and your attitude) kiss goodbye to the bike and say hello to a few hundred quid in fines and points on your licence.
Oh, and you'll have to tell insurers about your offences for five years or so, the few that will actually insure you will charge thousands instead of hundreds.
RyanBillingto...
PostPosted: 14:34 - 17 Apr 2014    Post subject: Gilera DNA Reply with quote
Hello,
Thanks for your replies.
I can confirm that my cousins bikes did do 50mph on the flat. My uncle has had bikes for over 40 years and he worked and road-tested them and he's the person who's currently helping me with mine.
I agree that it would just be easier to get a 125, but it all comes down to money. I could sell my Gilera and buy a 125 easily, but the insurance on a 125 for someone who's 17 with 0 years no claims is phenomenally expensive.
The Gilera DNA can reach 50mph. It's been shown to reach 70 on Youtube (but that wouldn't be too healthy for the bike and the credibility of the video is questionable).
The Gilera itself looks like a bike, rather than a ped. So my intention was to be able to get it to reach 50mph and stick with it for a year, and then move onto a 125.
I may try even lighter rollers etc, but while im buying lots of small things to work on it, I would be saving up for the insurance on a 125.
I just wondered if anyone had any ideas about what could be holding it back so substantially, as there's something we may have overlooked with one of the ''newer (2005 lol) models.
Thank you for your responses.
hmmmnz
PostPosted: 14:59 - 17 Apr 2014    Post subject: Reply with quote
have you take the spacer out of the variator???
id change to a 7 gram roller or a combo of 6 and 7's
couldnt hurt with the new cdi, but if you are reaching 13k rpm, it would suggest that you arn't rev limited
the humans are dead
I kick arse for the lord
The last post was made 12 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 127.91 Kb
