Mod 1 test tips?
ian3mith
PostPosted: 15:19 - 17 Apr 2014    Post subject: Mod 1 test tips? Reply with quote
any tips for mod1 test? Smile
mikesaa309
PostPosted: 15:32 - 17 Apr 2014    Post subject: Reply with quote
Just keep calm it's by far the easiest out of the two IMO. I've passed mod 1 doing mod 2 next week.
Just rememberer the obvious such as keep your head up and look where you want to go especially on the figure of 8 and also don't take that too tight take it wide but not stupidly wide.
Also don't forget that you're suppose to imagine that it's on the public highway so life savers are a must before moving off and before changing direction.
The speed trap was the bit I was most concerned with having to make sure you get to speed but also looking where you're going. The area I was in was quite small and there was no possible way on earth you could hold 30 through the bend (you might be in a bigger area). I just held the fastest speed possible then as I was exiting the bend rolled open the throttle. Once you've passed the speed trap you can shut of the throttle to take the serve but I suggest just backing it off a bit to maintain the speed. You don't really want to be accelerating or slowing during the swerve. And remember not to look at the cones but look ahead.
The slow ride is easy just hold the throttle open whilst holding the clutch in the friction zone. Use the clutch to alter the speed as well as feather the back brake (do not touch the front brake). Again head up looking where you want to go. If you live in a busy area like I do with annoying slow car drivers and presuming you've ridden a 125 for awhile then slow riding should be a piece of cake. Don't forget shoulder checks before pulling away.
Remember that as soon as you get on the bike the test has began so even parked up I suggest doing shoulder checks before pulling away.
Good luck on your mod 1, I'm sure you'll do just fine Thumbs Up
BG5067
PostPosted: 15:40 - 17 Apr 2014    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=284963
this may help.
Current. Kawasaki ZX9R.
Theory passed 17/01/2014. Mod 1 Passed 03/02/2014 (0 faults) Mod 2 10/02/2014 Passed (0 faults)
PostPosted: 18:01 - 17 Apr 2014    Post subject: Reply with quote
Good stuff from mike. I'll just emphasise that mod 1 is not hard.
Yes, it's easy to fail on something silly like dabbing a foot down in the u-turn or slalom, but there's nothing in it that you won't have done before at some point. It'll be test nerves that get you.
So: before starting any manoeuvre, take a deep breath, if you're in any doubt about what's being expected, ask, another break, lifesaver, and smash it in.
Sabs
PostPosted: 19:17 - 17 Apr 2014    Post subject: Reply with quote
This for sure. Everything else too, but definitely this, take a breath and go through in your mind what you've been asked to do.
My Photos
Theory in the bag, Mod 1 passed 28/3/2014, Mod 2 passed 9/4/2014 - Let loose
Kawaski ER6-f
TheSmiler
PostPosted: 14:16 - 18 Apr 2014    Post subject: Reply with quote
Slow riding is easy think take care, tether the clutch with throttle and back brake. U turn can be done in half the distance, when you come to do it do your safety checks move forward shoulder glance to right, forward right then right again as you turn. That was the best way I found (so they can't say you moved too far forward without checking).
On the high speed maneuvers try not to lock the back brake.
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 50.07 Kb
