Mikuni VM18 Flange Mount
marty tilley
PostPosted: 21:19 - 17 Apr 2014    Post subject: Mikuni VM18 Flange Mount Reply with quote
My 1966 suzuki b100p has a Mikuni Carb that I want to replace with a new one. Treatland told me they have a 20MM vm20 carb that has the flange mount , however the vm18 is no longer made. Anyone know where they may sell a vm18 with flange mount. Or if there is some conversion where I could make it work
temeluchus
PostPosted: 23:13 - 17 Apr 2014    Post subject: Reply with quote
I think the VM18 spigot carb is still made. You can purchase a rubber flange to mount the spigot carb to the bike.
You should be able to buy the needle jets, jets etc to match stock jetting on the original.
temeluchus
PostPosted: 01:05 - 18 Apr 2014    Post subject: Reply with quote
https://www.allensperformance.co.uk/vm18-144.html
marty tilley
PostPosted: 01:54 - 18 Apr 2014    Post subject: Reply with quote
Thanks for the link. I have seen those clamp on carbs , however can't seem to find a place that sells a rubber to mount it to the flange mount . That webapage has a lot of parts but can't find that type of mount to go with the clamp on .
temeluchus
PostPosted: 02:07 - 18 Apr 2014    Post subject: Reply with quote
My apologies,
to clarify the VM18 144 is the clamp on type. It seems to still be listed and I can find them in stock on ebay.
marty tilley
PostPosted: 19:09 - 18 Apr 2014    Post subject: Reply with quote
Yes I see the vm-20 thanks. 2 bad I can't find the vm18 flange mount instead of clamp mount. Do you know a place for a 18mm clamp to flange adapter? There is the vm-20 which is offered in a flange mount. Not sure if I could make a 20mm flange mount fit a 18mm flange mount.
marty tilley
PostPosted: 03:41 - 23 Apr 2014    Post subject: Reply with quote
Ok I found out the 18mm mikuni flange mount carb is no longer made. The after market spigot type I can't find a flange adapter anywhere to make it fit my bike . Ebay I have been checking for months for a used one with a good body. Anyone with experience with the b100p suzuki replacing the carb?
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 50.99 Kb
