DT400 poor starting?
tight fart
PostPosted: 09:54 - 18 Apr 2014    Post subject: DT400 poor starting? Reply with quote
My DT400 is not easy to start, it has a new plug and is getting a good spark, fresh fuel in the tank, good compression etc, to good I'm knackered after a few kicks, what next to look at and check?
(For the young ones it's a 1976 Yamaha 2 stroke single)
bypass2
PostPosted: 11:24 - 18 Apr 2014    Post subject: Reply with quote
When was the last time it was started. is the petrol getting to the plug. what about bump start in 2nd or 3rd gear. if it not started for ages may need a carb clean.have you tried a bit of petrol down the plug hole then try kicking it.
smegballs
PostPosted: 13:07 - 18 Apr 2014    Post subject: Reply with quote
Pretty jealous of you having that bike! It was my dream bike along with DT250 when i was 17/18 (which was around 2007, to give you an idea of how old I am).
Teflon-Mike
tl;dr
PostPosted: 13:20 - 18 Apr 2014    Post subject: Re: DT400 poor starting? Reply with quote
Its easter... has this bike been laid up over winter by any chance?
Checks?
- Exhaust rot
- Points and condenser.
- Reed-block
- Primary seals.
- Blood Pressure.. getting old has little to recommend it! Might have just lost the knack over winter though.... Wink
tight fart
PostPosted: 13:55 - 18 Apr 2014    Post subject: Reply with quote
I'm using fresh fuel from a temporary fuel tank now, there are no points on the 400s, reed block is something I hadn't considered, could be that, as it won't start on easy start.
I have just checked the ignition timing and still getting a good spark.
tight fart
PostPosted: 20:09 - 18 Apr 2014    Post subject: Reply with quote
Reeds not looking good but not blocked or stuck, I've turned them around so they now sit flush, the ign timing is spot on, but it still won't run.
bypass2
PostPosted: 20:45 - 18 Apr 2014    Post subject: Reply with quote
what about try a different plug. have you cleaned the carb
tight fart
PostPosted: 20:51 - 18 Apr 2014    Post subject: Reply with quote
Funnily enough I've just ordered a new plug, the one in there is new and looks like Its giving a good spark but I can't see what else it can be?
tight fart
PostPosted: 07:32 - 20 Apr 2014    Post subject: Reply with quote
I've given up for now till the new plug arrives via eBay
[/img]
tight fart
PostPosted: 18:02 - 26 Apr 2014    Post subject: Reply with quote
Doh! Put new plug in and it appears I don't have a good spark after all.
Not sure where to start, it would be easier with points.
www.tightfart.com
bypass2
PostPosted: 18:54 - 26 Apr 2014    Post subject: Reply with quote
What about the woodruff key worn. fly wheel nut loose. faulty ht lead .plug cap. faulty wires around the coil. bad earth. When was the last time you started it.
tight fart
PostPosted: 20:02 - 26 Apr 2014    Post subject: Reply with quote
I think if the woodruff key had worn I'd have a spark but at the wrong time, faulty lead or cap maybe, not sure How to check that other than replacing, the lead I think is bonded into the coil.
I've not used it for a while but the bugger wouldn't start and I put it in the shed till I had time to look at it.
www.tightfart.com
tight fart
PostPosted: 20:51 - 30 Apr 2014    Post subject: Reply with quote
Vincent wrote:
IIRC, the CDI on the DT was one of the first for Yamaha and was pants, ('probably suffered damage from vibration). Might be worth looking there first.
I've looked at it, can't see what else I can do apart from look.
www.tightfart.com
bypass2
PostPosted: 22:13 - 30 Apr 2014    Post subject: Reply with quote
maybe a faulty kill switch.faulty earth wire or live wire. does the battery have to be charged up. does the horn/lights/all work. fuses blown.take the plug out and spray some wd40 inside the kill switch inside the fly wheel around the wiring then kick it over a few times and see if the plug sparks then.
moonzoomer
PostPosted: 22:16 - 30 Apr 2014    Post subject: Reply with quote
Check your bottom coils for a good output, you may have an output but it could be too low.
Piercee100
PostPosted: 07:49 - 01 May 2014    Post subject: Reply with quote
The CDI on my 1980 H100a was playing up a while back causing similar symptoms. It was hanging loose between the petrol tank and the frame but I cant really see a reason for it playing up. I just unplugged it, cleaned the contacts, re-attached and it's good to go. It doesnt like the wet so I made sure all contact areas were covered with a bit of electrical tape and has been fine for a year now.
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 98.03 Kb
