What kind of light fitting is this?
Andy9934
PostPosted: 12:54 - 19 Apr 2014    Post subject: What kind of light fitting is this? Reply with quote
I just got a YBR 125 and the front light wiring is very bad. Where the wires come in they have broken away from the circuit board, which allowed the connections to short. I've fixed it for the time being but I'd like to put LEDs in.
Searches suggest that the stock part is an H4 bulb which looks very different to this so I am concerned I need something else to fit the fitting but I can't ID mine.
https://i.imgur.com/2ZSvc1Hm.png
zark
PostPosted: 13:57 - 19 Apr 2014    Post subject: Reply with quote
BA20D
Good luck. It's a dual filament (so it does the dipped and full beam)
All the led bulbs I've seen are only one beam... So you may lose your full beam which may or may not matter, depending on how good your dipped beam is! You might need a full beam for an mot too?
I went for a halogen type upgrade on mine... It's not great, but m much less hassle than his or led... As far as I can work out.
Llama-Farmer
PostPosted: 15:15 - 19 Apr 2014    Post subject: Reply with quote
As mentioned, its a BA20D, sometimes coded as 395 or H6M. They come in various different power ratings though from 18/18w up to 35/35w, use the wrong power rating it can melt the wiring or blow the fuse if the rating is too high (or barely visible if the rating is too low).
Could be that someone bodged that connector in... pulling the wires out, re-stripping them and properly connecting it to the bulb unit should stop shorting.
Check out these CREE LED ones, they should be what you want... don't use Crees on the bike, but I've got them in everything (except the headlights) on my car and they're brilliant.
https://www.hids-direct.co.uk/h6m-395-ba20d-5w-cree-xtreme-white-xenon-motorbike-bulbs/
They should do both dipped and high beam as that is what the 395/BA20D bulb is designed to do... can't see how or why they would sell "single-filament" bulbs to do the job of a "twin-filament" bulb
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
Andy9934
PostPosted: 16:24 - 19 Apr 2014    Post subject: Reply with quote
Wow, thanks for the quick response!
It has been bodged, and badly too. Thanks for the bulb suggestion, they don't have the "skirt" though?
Llama-Farmer
PostPosted: 16:32 - 19 Apr 2014    Post subject: Reply with quote
Ah so they don't.
Hmmm, these ones do.. and it looks like maybe you've got the light out the front of the bulb for full beam and the light coming out the side of the bulb for dipped.
https://www.hids-direct.co.uk/h6m-p-15d-25-1-11-5050-smd-led-white-motorbike-atv-bulbs-pair/
Andy9934
PostPosted: 18:46 - 29 Apr 2014    Post subject: Reply with quote
I think the old one was a H6M.
I bought a BA20d bulb which fits the lamp head but the old connector doesn't fit.
I want to replace the connector too but I can't seem to find one for ba20d bulbs so I think I am going to have to hunt down another bulb now which will fit the casing instead.
I am still surprised that a professional garage did such a bad job.
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 57.83 Kb
