MOT Failure: Front Suspension
podmore71
PostPosted: 15:53 - 19 Apr 2014    Post subject: MOT Failure: Front Suspension Reply with quote
Well my little Honda Lead 100 failed it's MOT the other day due to the front suspension being stiff. In fact, there is no movement in it at all. I was advised by the mechanic, that this is a common fault with the Honda Lead and that a strip down, clean and lubrication would probably cure it.
My question is this. What solvent should I use to clean the parts after I remove them?
What should I be using as a lubricant?
I have attached a photo of the front suspension so you can see the type it is. I think its called 'Leading Link or monolever' type suspension. But I could be totally wrong.
Teflon-Mike
tl;dr
PostPosted: 16:27 - 19 Apr 2014    Post subject: Re: MOT Failure: Front Suspension Reply with quote
Err... this seems to be missing from my browser....
Anyway, solvent. Petrol used to be conveniently handy and good, but rather preciouse now.
Once you have pice-parts in your hand; scrub with hot soapy water.
Boliogical washing deturgent is good and cheap; washing up liquid is kinder to your hands. Bio Powder does tend to leave a residue though so second rince with fairly liquid often needed anyway; but does shift more shit, I find.
Use wet and dry sandpaper wetted with washing up liquid to clean stubborn rust from moving bits of metal.
Grease up with Low Melting Point grease of Graphite grease, whatever is handy. (In the third world has been known for folk to use Ghee and the like, but I cant say I have ever tried it, or could reccomend it!)
Check for play in moving parts as you re-assemble; if very rusty shifting the stuff that stops it moving can leave bludy great gaps.
podmore71
PostPosted: 17:13 - 19 Apr 2014    Post subject: Reply with quote
Sorry about that. For some reason the picture didn't show up. I'll try it again
Thanks for the Tips Mike.
smegballs
PostPosted: 17:27 - 19 Apr 2014    Post subject: Reply with quote
I find the easiest way to put images here on bcf is to use imgur.com.
Just upload you pic there, and it will automatically generate the [img] tags which you can then just paste into a bcf post.
podmore71
PostPosted: 11:34 - 20 Apr 2014    Post subject: Reply with quote
Cheers for that.
Here goes for a third time
https://i.imgur.com/97ezaME.jpg
podmore71
PostPosted: 11:35 - 20 Apr 2014    Post subject: Reply with quote
Exclamation Exclamation Exclamation Think that is a bit too big. Confused
smegballs
PostPosted: 14:32 - 20 Apr 2014    Post subject: Reply with quote
If you put a "l" after the last letter in the imgur code it makes it smaller.
https://i.imgur.com/97ezaMEl.jpg
[picher]https://i.imgur.com/97ezaMEl.jpg[/picher]
Took me a while to learn how to use img codes, but they are handy once you get used to it. I think the l suffix is unique to imgur tho.
moonzoomer
PostPosted: 17:14 - 20 Apr 2014    Post subject: Reply with quote
Remove front wheel, clean and grease axle/spacers as needed .
Remove both pivot point bolts (bottom left of pic) clean and grease as needed using anti-seize grease (copaslip)
Check the central damping units for clean and smooth operation by putting the forks onto a couple of concrete blocks (minus wheel) and pushing down on the front of the bike.
kramdra
PostPosted: 18:42 - 20 Apr 2014    Post subject: Reply with quote
Ghee and washing powder is far from ideal Mike. Wahing up liquid contains a large amount of salt so best avioded.
I find water solouble cleaners are not great. Solvents are far more effective. Paraffin is cheap and considered much safer than petrol. Car washing soap is good for rinsing off parts.
PostPosted: 22:13 - 20 Apr 2014    Post subject: Reply with quote
Washed off and greased up afterwards, I wouldn't worry in the slightest about any salt in the washing up liquid.
podmore71
PostPosted: 10:45 - 29 Apr 2014    Post subject: Reply with quote
Well boys I've managed to sort out the suspension.
I got hold of some replacement links and suspension springs from ebay, and I've got it all back together.
I've just tested the suspension and its looking good. Proper movement this time. Thank god.
The problem I have now is refitting my front break cable. No matter what I do, whenever I pull on the front break lever and release it, the front breaks don't release. If I adjust the breaks then the pads bind on the wheel.
When I took off the wheel, I pulled the break drum out by mistake. I think I put it back in correctly but I can't be sure. As far as I know Embarassed
Any ideas guys
Andy
smegballs
PostPosted: 10:56 - 29 Apr 2014    Post subject: Reply with quote
What state was the break cam shaft (pic related)in? I always give them a good wiring brushing and a little smear of grease (not too much, dont want to contaminate the shoes) to keep it all working smoothly and not binding up.
https://yambits.co.uk/images/BSP074.JPG
Want to take some pics of the wheel/cable as you've assembled to help us diagnose?
podmore71
PostPosted: 11:03 - 29 Apr 2014    Post subject: Reply with quote
Thanks Smeg.
I've just removed the wheel again. There is a lot of dust in there so it could probably do with cleaning all out. The arm on the drum is very stiff. Not sure if thats normal or not.
podmore71
PostPosted: 11:20 - 29 Apr 2014    Post subject: Reply with quote
Well I don't know what I've done differently but I've just taken some photos of the break drum and lever. Put it back on and now it seems to be working fine.
Well bugger me with a fish fork is all I can say lol
smegballs
PostPosted: 11:21 - 29 Apr 2014    Post subject: Reply with quote
By arm do you mean this bit?
https://yambits.co.uk/images/BSP034.JPG
The star on the arm, fits the splines on the camshaft in my last pic, the whole thing needs to be free of dust and corrosion and shit to work nicely, the springs on the brake shoes should be enough to easily ping the lever back when you actuate the brakes by hand, with the wheel off and the cable disconnected.
Sounds to me like the whole thing needs a good wire brushing, and re-assembly with a little grease on the shaft. On the plus side, it doesn't really cost much to service drum brakes! Just a little elbow grease, no brake fluid or seals to much about with either!
podmore71
PostPosted: 13:49 - 29 Apr 2014    Post subject: Reply with quote
That's the fella.
It does need a strip down and a good clean. I'll try and get some break cleaner and copper grease some time this week. As for the bike. Well I've just finished replacing all the body panels and just took it for a very quick spin around the block. Breaks are as they were before I started (thank the gods, lol) and the suspension is, well I can only say, it feels perfect. Plenty of bounce in the front forks. The old springs seemed ok to me but considering I got another set with the links I bought off Ebay I thought I'd swap them out anyway. A hell of a lot simpler than I thought it would be. I feel so proud of myself for having a go and doing it myself. Just hope it now passes its MOT tomorrow.
Thanks everyone for the sound advice and help. Very much appreciated.
I love places like these boards. Everybody is just so dam helpful Smile
Andy
The last post was made 12 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 91.36 Kb
