Kawasaki KMX 200 rear shock dissasembly
dangerousdave
PostPosted: 18:53 - 19 Apr 2014    Post subject: Kawasaki KMX 200 rear shock dissasembly Reply with quote
This afternoon had a go at dismantling a rear shock from a Kawasaki KMX 200.
https://i1329.photobucket.com/albums/w544/bikemars100/kmx%20shock/DSC_0724_zpsanyi9xqo.jpg
All went fine until trying to dissasemble the damper rod.
Looks a little like a circlip, but with no tangs to get circlip pliers in to. No idea how to remove this, anybody else have an idea?
https://i1329.photobucket.com/albums/w544/bikemars100/kmx%20shock/DSC_0721_zpsekmyvun_edit_1397933575783_zpscymkhg7l.jpg
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
slowlydoesit
PostPosted: 10:35 - 20 Apr 2014    Post subject: Re: Kawasaki KMX 200 rear shock dissasembly Reply with quote
Can't help, but would like to know the answer as well.
Thought you had finished your KMX project and moved on...?
Kawasaki KMX200 with broken fixed powervalves and a stutter
joef
PostPosted: 10:43 - 20 Apr 2014    Post subject: Reply with quote
The picture is too zoomed in to see it properly tbh. Are you sure it's supposed to be removed?
edit: Does the black bit with the serrated edge not unscrew?
- 1981 Honda CB250N Superdream -
dangerousdave
PostPosted: 16:46 - 20 Apr 2014    Post subject: Re: Kawasaki KMX 200 rear shock dissasembly Reply with quote
Haven't moved on, still have it. Its just not getting used much at the moment.
This is a spare shock I have, thought would have a look at what is inside and attempt a rebuild.
Saw an article in Practical Sportsbikes about rebuilding this type of shock but it didn't go into detail around this part of the dissasembly.
The black rubber seal (with the rough edge) may well come out, but will likely tear when coming apart.
The seal is the part which needs to be replaced as it's slowly leaking oil, anyone know where I could buy a replacement?
The last post was made 12 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 41.35 Kb
