Bike wont start. Battery Problem?
Gazz
PostPosted: 20:44 - 19 Apr 2014    Post subject: Bike wont start. Battery Problem? Reply with quote
Took the Deauville out for the first time this year.
Battery was fucked so I bought a new one; "Yuasa" as was recommended by the Halfords battery guide.
Got it home and fitted it and the bike started fine.
Tried to start it later the same night and the bike was difficult to start but eventually started.
However, I tried to start it this morning and nothing is happening.
The lights and the clock on the dash are on, but it wont even attempt to turn over.
Also the clock on the dash is very bright when the keys are in the 'off' position, but once you turn the keys to the 'on' position the clock fades, etc.
Any suggestions?
I have also had a look at the kill switch and side stand sensor - just in case they were to blame, but they seem to be fine.
bypass2
PostPosted: 20:54 - 19 Apr 2014    Post subject: Reply with quote
what about a faulty/ Loose earth at the battery or one of the fuses /wire loose.is it the right ampage battery for the bike. maybe the new battery is duff.
clancy
PostPosted: 21:02 - 19 Apr 2014    Post subject: Reply with quote
Today you said nothing happened
Literally nothing? No clicking ? Whurring or noises from anywhere?
How long since it was last started ?
KLX 300r
Gazz
PostPosted: 21:20 - 19 Apr 2014    Post subject: Reply with quote
Yes, nothing at all. No clicking or any other noises. (only when you let go of the start switch and it goes back to its normal position)
Bike was ran last night. Got home about 9ish and it was just before 9am this morning that I tried to start it.
Also, checked the earth terminal on the battery and it seems fine.
clancy
PostPosted: 21:40 - 19 Apr 2014    Post subject: Reply with quote
Before last night was it left for a fairly long time ?
Might not be but, check the starter motor isn't seized ( when it is, it can have off and on moments so isn't consistently useless) check by hitting the starter motor fairly hard whilst holding down the start button of the bike. Of it still does nothing after a few attempts it probably isn't that.
If you don't know what I mean, locate the starter motor, see the 5 mm or so circular section, will be the cleanest looking part of the starter, put a flat head screw driver against it and tapp it with a hammer whilst holding the start button. When my starter motor siezed it would still start this way
KLX 300r
Scotsman37
PostPosted: 15:11 - 20 Apr 2014    Post subject: Reply with quote
Could it be your Alternator because all you've been doing is draining the battery of power without charging it up again while its on?
I would double check the battery with a volt meter to see if the voltage has dropped below 12v, and leave it connected to see what happens when you even press the Starter button?
PostPosted: 15:23 - 20 Apr 2014    Post subject: Reply with quote
Regulator?
Get it started and check voltage across terminals.
moonzoomer
PostPosted: 17:07 - 20 Apr 2014    Post subject: Reply with quote
Charge your battery, take the plugs out and clean or replace. Reconnect battery with ignition in the OFF position and watch for sparks as you connect the terminals, if there is a spark then there is a drain on your battery which will need to be traced. as already mentioned check the static voltage of the battery before starting the bike and check while the bike is running, there should be a slight increase which will also show with the lights changing in brightness as the bike is revved.
Gazz
PostPosted: 13:12 - 21 Apr 2014    Post subject: Reply with quote
Charged the battery last night and the bike started fine this morning.
Battery is reading 11.5 when the bike is running and 11.9 when the bike is turned off which I find slightly odd. No increase in numbers when the bike is revved or anything.
Should I be concerned about this?
Is the bike likely to die on me again tomorrow morning?
Rob W
PostPosted: 15:09 - 21 Apr 2014    Post subject: Reply with quote
Sounds like your reg/rec is fried, those voltages are far too low. I wouldn't be riding it til you get it sorted, the bike will just die on you as its not properly charging the battery.
RhynoCZ
PostPosted: 15:39 - 21 Apr 2014    Post subject: Reply with quote
It's, maybe, the stator.
Find where 3 yellow wires come out of the engine. Start the engine, set the multimeter to AC and meassure the wires with each other, you should get around 60v out of there, possibly less, but you've got to get something. Take two yellow wires, check them, then other 2 yellow wires and the last combination of 2 yellow wires.
Scotsman37
PostPosted: 16:09 - 21 Apr 2014    Post subject: Reply with quote
Yes, I would definitely concur don't ride till you've found the culprit that needs sorting otherwise you stop somewhere away from home and that bike will not start up again because there is absolutely no juice going back into the battery to replenish what is getting used to spark the the fuel in the carbs and your bike's lights too.
Gazz
PostPosted: 16:40 - 21 Apr 2014    Post subject: Reply with quote
The reg/rec was changed a couple of months ago, just before the winter. It blew the main fuse on the way to work one day.
PostPosted: 16:43 - 21 Apr 2014    Post subject: Reply with quote
Set multimeter to AC volts.
Check each of the wires from the stator that plug into the reg rec, likely 3 yellow ones. + on the wire - on earth/frame. All 3 should be roughly equal and it should hopefully increase voltage when revved. If one is duff, voltage doesn't increase of you have fuck all, check continuity between them.
Looking for the same between 1+3, 2+3 and 1+2, hopefully as close to zero as possible.
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 77.94 Kb
