Cheap/easy idea for garage alarm.
smegballs
PostPosted: 21:00 - 19 Apr 2014    Post subject: Cheap/easy idea for garage alarm. Reply with quote
Thought about a simple garage alarm that could be cobbled together from junk box items. No need for mains power (as I've seen a fair few of you with garages but no mains leccy), just give the battery a charge now and then. No electronics/soldering required - it can all be done with normal auto crimp connectors and off the shelf parts.
https://i.imgur.com/eK00BJq.png
The "trigger switch" is up to your own ingenuity. An easy one would be to wrap wires around two sides of a clothes peg to make the switch, separating each side of the peg is an insulator attached to a line tied to the shed/garage door. If the shed door is opened, it pulls the insulator out, the clothes peg sides come together and close the switch.
https://i.imgur.com/F7ynqpr.png
Obviously you can sub any 12V horn for the nautilus, however pant-shitting may not be achieved with quieter horns.
Dear GCHQ/NSA don't put me on another watchlist for that image of the peg trigger device. This is a perfectly legit application for such a switch. Thankyouplease Laughing
Major Doss
PostPosted: 22:12 - 19 Apr 2014    Post subject: Reply with quote
A very tidy notion to use parts which many will have laying redundant. Thumbs Up The trigger could even be multiplied in series to cover windows and such like. Very clever, Smeggers!
Antisocial phucker.
-Matt-
PostPosted: 22:14 - 19 Apr 2014    Post subject: Reply with quote
Very interesting to read as someone with zero-electronics knowledge Razz
If you are looking for alarm though - i've had suprisingly good results from cheap PIR alarm systems in the past. Picked a new one up from a local 'pound shop' for about a fiver last week. They are battery dependant so ideally get some rechargeables and replace them every couple of months to be safe, but seem fairly reliable.
I tend to mount them near the door as its the first large object likely to trigger it and temporarily will hide/block the alarm from being fiddled with once its activated it once the doors flipped. Generally come with one or two wireless remotes [again battery reliant so something to keep going], they're not great on range but i've found they tend to respond once you're near the door so you can just deactivate and unlock at the same time.
smegballs
PostPosted: 22:44 - 19 Apr 2014    Post subject: Reply with quote
That was the idea, I could start going on about 555 timer circuits to make the on-off pulses and then using transistors to handle the current but that would just alienate a good 90+% of readers.
Plenty of bikers have replaced an flasher relay, and there is countless guides on how to wire up a standard 4-pin automotive relay (there's even one in the bcf workshop guides section).
I would dearly like to see the scrotes faces when a stebel goes off in an enclosed space in the dead of night. I'd probably trip it myself one day and shit bricks.
Joncrete Cungle
PostPosted: 00:34 - 20 Apr 2014    Post subject: Reply with quote
https://www.henrykrank.com/index.php?main_page=product_info&products_id=2964 Thumbs Up
i.p.phrealy
PostPosted: 12:34 - 20 Apr 2014    Post subject: Reply with quote
Joncrete Cungle wrote:
WANT! Laughing
WD Forte
PostPosted: 15:51 - 20 Apr 2014    Post subject: Reply with quote
Keeping it simple
The ex bike/car /van battery would fare better in a box to keep it warm
rather then left to sit on a cold floor as they dont like it up em.
If its got an 'up and over' door,
You can buy mercury type tilt switches very cheaply from Ebay
or Maplins ( dearer) if in a rush
( if you see free standing electric heater in a skip it will/should have a tilt switch inside that can be salvaged)
I'd consider using a keyswitch on the door to arm/disarm it plus
an on/off led.
you'd only need 20mm and 5mm holes for these
and just the presence of them may dissuade the casual or
opportunistic theives
If you want go more complex the possibilities are endless
bikers smell of wee
The last post was made 12 years, 114 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 54.15 Kb
