honda cg 125 es bike wont start
simonjay
PostPosted: 13:36 - 20 Apr 2014    Post subject: honda cg 125 es bike wont start Reply with quote
bike wont start off the button and when i press the start button the headlight goes out and the relay under the seat clicks
any ideas im thinking dud battery?
Mark65
PostPosted: 13:48 - 20 Apr 2014    Post subject: Reply with quote
Could be starter motor brushes, try putting in gear then rocking back an forth, then have another go, if it does it a lot take starter apart and check, I have had it twice now . I think carbon dust off the brushes in use gets in them and makes them stick now an then.
Charge battery or try another.
Mark
blurredman
PostPosted: 14:37 - 20 Apr 2014    Post subject: Reply with quote
Might also help to turn off lights when in the process of starting. It can save a bit of juice for the cranking on a dodgy battery.
Charge battery for many hours, and try again.
simonjay
PostPosted: 14:50 - 20 Apr 2014    Post subject: Reply with quote
the es model lights stay on permanent ive tried rocking backwards and forwards didn't work will strip starter motor down tonight
TheSmiler
PostPosted: 15:00 - 20 Apr 2014    Post subject: Re: honda cg 125 es bike wont start Reply with quote
Personally I'd see if you can bump start it, CG125's are extremely easy to bump start. Does sound like the battery is extremely low, if you get it to start keep it running on idle for a few minutes see if you can get some power to the battery.
Also if you have a multimeter get it on the battery to find out what it's reading.
Mark65
PostPosted: 18:54 - 20 Apr 2014    Post subject: Reply with quote
Yep, try charging first or borrow a battery, do the easy stuff first.
alt tab
PostPosted: 19:04 - 20 Apr 2014    Post subject: Reply with quote
Had this issue with my CG after failing to start it many times on the electric start, the battery was simply out of juice. My model came with the kick start in addition to electric start, not sure about yours, if it does, kick it and go from there.
Best thing you could do is bump start it, should be nice and easy to do, then keep the revs up, do a couple of laps of the block or whatever to get the rev count over 5000 rpm (it's at this point the alternator kicks in, I believe).
This should resolve your issue, giving the battery a bit of charge back. Failing that, new battery (which as far as I understand, is rarely needed unless the bikes sat for a long time)
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 52.65 Kb
