Weird spark issue
y2daz
PostPosted: 12:09 - 21 Apr 2014    Post subject: Weird spark issue Reply with quote
Hi there , I'm currently working on a vulcan custom 125 which has lost its spark. After much fiddling and mooching i discovered that if i flick the kill switch from off to on whilst turning the engine over i get a single spark , it will do this every time i flick the switch.
Anyone got any suggestions.
Thanks in advance
Daz
PostPosted: 12:43 - 21 Apr 2014    Post subject: Reply with quote
Kill switch earths the low tension side of the coil. It sparking when you do that implies the system for producing the spark is working but nothing is allowing the low tension side to earth at the correct time.
I suspect you probably have a problem with your pickup coils or the wires leading to/from them.
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 31.16 Kb
