Suzuki DR 125SM not turning over. These wires to blame?[pic]
Queeg500
PostPosted: 13:33 - 21 Apr 2014    Post subject: Suzuki DR 125SM not turning over. These wires to blame?[pic] Reply with quote
My bike is a Suzuki DR 125 sm k9, recently the engine would no longer turn over, the FI light came on and the error code suggested a problem with the ignition, upon inspecting the ignition I found some wires had been damaged, I've just repaired those.
The battery (few months old) has been on a trickle charger for a few days since the bike developed the initial fault, upon reinstalling it I noticed the wires pictured below. When I try to start the bike now I no longer get the FI warning light but the bike wont turn over, I've no reason to believe the battery is faulty, lights look bright as ever, instrument cluster is working and as far as I can test it with a multimeter it seems ok. I've checked all the obvious, kill switch etc.
I accidentally touched wires 1 and 2 and the bike turned over as strong as it should, wire 3 runs straight into the bike and 4 + 5 look like earth wires. I'm guessing this is where the fault lies as the battery fell out and snagged on its wires when I removed it, so that has probably pulled these wires apart (?).
Cheers!
https://s21.postimg.org/pwo4kn52f/wires.jpg
Queeg500
PostPosted: 16:09 - 21 Apr 2014    Post subject: Reply with quote
Well after some head scratching I realised that those cables all plugged into the starter solenoid!
I connected everything together and still no spark and it's not even trying to start. Out of curiosity (and without knowing the consequences) I decided to directly connect the red and red/white wire after removing them from the solenoid, again the starter turns over (even with the ignition off).
Does this mean my solenoid is faulty?
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 31.86 Kb
