AM6 engine damage advice??? Furia 50cc
Dan Moto
PostPosted: 13:43 - 21 Apr 2014    Post subject: AM6 engine damage advice??? Furia 50cc Reply with quote
Posted this in my project part but no replies, come to take the engine out of the bike and noticed there is some damage to the casings. Obviously the cases need replacing but should I just buy a replacement engine an go from there it the am6 50cc.
https://www.bikechatforums.com/files/image_159.jpg
https://www.bikechatforums.com/files/image_162.jpg
Life's Short Have Fun, Grab The Bull By the Horns And Give It A Shake.
Never Say Never... As It Might Just Happen, If It To Good To Be True It Probably Is.
Wake Up And Smell The Coffee, If It Ain't Broke Don't Fix It As then It Will Be.
The Artist
PostPosted: 13:50 - 21 Apr 2014    Post subject: Reply with quote
The first pic is standard damage on AM6.
The 2nd is a bit unusual. Not really sure, do you have more pictures from the area?
Dan Moto
PostPosted: 13:57 - 21 Apr 2014    Post subject: Reply with quote
Will take one now.
Dan Moto
PostPosted: 14:06 - 21 Apr 2014    Post subject: Reply with quote
Thanks for the reply here's the pics.
https://www.bikechatforums.com/files/image_402.jpg
https://www.bikechatforums.com/files/image_808.jpg
It's near the kick start on the case.
The Artist
PostPosted: 14:27 - 21 Apr 2014    Post subject: Reply with quote
It is possible the kick starter gear has come off. Behind the input shaft, there is a gear mechanism and it looks like it has kicked outwards.
I would take the covers off and inspect. It isn't necessarily structurally important IIRC.
Also, that bolt in the top looks like a bodge job which isn't a good sign. It means someone has had a go at fixing something and not done it properly so there could be other hidden issues.
Dan Moto
PostPosted: 14:33 - 21 Apr 2014    Post subject: Reply with quote
Ok thank you for the reply. I will take the covers off and inspect the cause I will post pics of my findings. also I am a a bit fussy and this bothers me so some cases or another engine will be purchased will probably strip this one for spare parts parts.
Dan Moto
PostPosted: 15:09 - 21 Apr 2014    Post subject: Reply with quote
Ok so removed the cover an find no gasket and the damage in the pics.
https://www.bikechatforums.com/files/image_168.jpg
https://www.bikechatforums.com/files/image_204.jpg
https://www.bikechatforums.com/files/image_485.jpg
Clearly a bodge job not sure what other horrors I'm going to find.
The Artist
PostPosted: 16:10 - 21 Apr 2014    Post subject: Reply with quote
That oversized bolt may well have caused the kickstart issue.
I would look around for a spare AM6 engine with solid casings.
Dan Moto
PostPosted: 16:55 - 21 Apr 2014    Post subject: Reply with quote
Was on the bay while typing watching a few at the mo. also are they easy to rebuild as it's my first project build thank for the replies and advice it much appreciated.
hmmmnz
PostPosted: 18:10 - 21 Apr 2014    Post subject: Reply with quote
yeah id be looking for another engine, and keeping that one as spares,
it looks repairable, but probably not economically so
the humans are dead
I kick arse for the lord
Dan Moto
PostPosted: 19:36 - 21 Apr 2014    Post subject: Reply with quote
Watching one on the bay it says running but won't select first gear, so if won was going to make a good one from both using a naraku piston set and crank shaft and naraku seals and other new bits if needed. But I will practice tacking it part and putting it back together never done owt like this before.
The Artist
PostPosted: 19:56 - 21 Apr 2014    Post subject: Reply with quote
They are pretty simple and a lot of people know them inside out so any issues, post pics and as much description as possible and someone will know.
If you plan on using this bike long term, expect a top end rebuild in 10k miles give or take depending on how you use it.
Dan Moto
PostPosted: 20:54 - 21 Apr 2014    Post subject: Reply with quote
Thanks it gives you piece of mind to know there's people with knowledge that are willing to help. And yeah I remember someone said top end rebuild every 10k or so.
The last post was made 12 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 78.63 Kb
